5 Replies Latest reply on Nov 26, 2015 7:22 AM by A.T. Romano
    426 x 240 video
    ernief73120713
      Can someone tell me what format i should set my project to to use 426 x 240 video? I set it to Mobile devices
      In Elements 14 the video is letter boxing, In Elements 11 it is not.
      Ernie
        • 1. Re: 426 x 240 video
          A.T. Romano Level 7
          Emief
          I would suggest that you get out of Expert & Share/Devices/Mobile and go to Expert & Share/Devices/Custom and create a custom preset with the H.264 format.
          What are you using for the project preset when you import this video into the new project? See Edit Menu/Project Settings/General.
          When you are viewing your import in the Edit area monitor, are there black borders around the image, and do you take the video into Expert & Share with that appearance?
          Please consider and give more details. When ready for Expert & Share, I will provide more detailed information if needed. Just let me know.
          Thank you.
          ATR
          • 2. Re: 426 x 240 video
            ernief73120713 Level 1
            Thanks ATR,
            I haven't gotten to exporting the movie.
            When I go to the general tab I'm unable to change the frame size
            There are black borders on the clips when i view them in the project assets.
            • 3. Re: 426 x 240 video
              A.T. Romano Level 7
              emief
              Premiere Elements does not have a project preset for 426 x 240 16:9, so this is what we are going to do...use a preset for 16:9 for the import and then export Export & Share/Devices/Custom for the 426 x 240.
              Open Premiere Elements to the Expert workspace and manually set the project preset to
              NTSC
              FLIP
              Flip Mino HD and Ultra HD 29.97;
              You manually set the project preset according to the following scheme
              • Open the project to the Expert workspace, and go to File Menu/New Project and Change Settings.
              • In Change Settings, set the project preset to one mentioned above. OK out of there.
              • In the New Project dialog that opens, rename the project and make sure to have a check mark next to "Force Selected Project Setting on This Project". OK out of there.
              • Back in the Expert workspace, import your source media using Add Media/Files and Folders/Project Assets from where you drag the file to the Timeline Video 1/Audio 1.
              Edit Menu/Project Settings/General is a place to see what settings have been set for the project. But, you cannot make significant changes there. If the project settings are not correct, you start a new project.
              Please consider, and then let us know if that worked for you.
              Thank you.
              ATR
              • 4. Re: 426 x 240 video
                Hey AT
                Using the flip setting worked in getting rid of
                The black borders.  Thanks
                • 5. Re: 426 x 240 video
                  A.T. Romano Level 7
                  emief
                  Thanks for the good news that the import settings suggestion worked for you. Well done.
                  Please let me know if you are OK with the export route that I suggested earlier, that is, Export & Share/Devices/Custom.
                  Best wishes
                  ATR
