3 Replies Latest reply on May 12, 2006 12:53 PM by JustStartingOut
    undefining variables
    radarguy1
      I am trying to make a reset button that will clear a set of variables and text boxes. The variables define coordinates that draw lines. When I think everything is reset and select new variables the last one is either zero, zero or null, null. The only way I can think of to eliminate this is to restart the movie. So her is the question: Is there either a way to undefine variable or to have a move restart itself from a button?
        • 1. Re: undefining variables
          Level 7
          radarguy1,
          I guess you're talking about the Var field in the Property inspector for
          each text field, right? Personally, I would go with the TextField.text
          property of each text field. To me, that makes more sense than linking text
          fields to a variable. Not saying it's wrong -- there's nothing wrong with
          what you're doing (assuming I've even guessed right!) -- but ehh, for what
          it's worth, that's my tiny soapbox.
          What if you set those variables to empty strings?
          You can delete variables (see the delete entry of the ActionScript
          Language Reference), but that might just set their values back to null.
          Worth a shot, though.
          David
          stiller (at) quip (dot) net
          Dev essays: http://www.quip.net/blog/
          "Luck is the residue of good design."
          • 2. Re: undefining variables
            .:}x-=V!P=-x{:. Level 3
            delete variableName;
            • 3. Re: undefining variables
              JustStartingOut
              And if not the delete command, maybe setting the value to undefined:
              on(release)
              { _root.myVarName = undefined; }
