2 Replies Latest reply on Dec 3, 2015 1:36 AM by steverocket2
    Below script is works fine but i want to make the proper structured script...please change or suggest me.
    Jackkistens
      Dear All,
      var myEveryName = new Array();
              var myEveryContent = new Array();
              var myEveryAttributes = new Array();
              var PrjAttr1= new Array();
              var PrjAttr2 = new Array();
              var PrjAttr3 = new Array();
      var myComment = myDoc.xmlElements[0].xmlComments[0].value;
      var xxx = myComment.substr(myComment.indexOf ("\" id",3));
      var projectTitle = myComment.replace(xxx,"").replace("<project title=\"","");
      var myfile = File("D:\\PC_TESTING\\"+projectTitle+"\\COVERS\\MergedInfoXML\\MergedInfo.xml");
              var myAttrValue = new Array();
              var myFinalAttrValue = new Array();
              var Simp = new Array();
              if(File(myfile).exists)
                        myfile.open("r");
                        var Cont= myfile.read();
                        var roots = new XML(Cont);
                        traverse(roots);
                           for(var i=0; i<myEveryName.length; i++)
                                  if(myEveryName[i] == "info")
                                          PrjAttr1.push(String(myEveryAttributes[i][0]));
                                          PrjAttr2.push(String(myEveryAttributes[i][1]));
                                          PrjAttr3.push(String(myEveryAttributes[i][2]));
                                    if("simple" == myEveryName[i])
                                          Simp.push(myEveryContent[i]);
                else
                      alert("NOT Exist");
                       exit(0);
      mySqrtTag(myDoc);
      function mySqrtTag(elm)
          for (var i = 0; i < elm.xmlElements.length; i++)
              if(elm.xmlElements[i].markupTag.name.toString() == "ce:intra-ref")
                  for(var j = 0; j < elm.xmlElements[i].xmlAttributes.length; j++)
                      if(elm.xmlElements[i].xmlAttributes[j].name == "xlink:href")
                              var atValue = elm.xmlElements[i].xmlAttributes[j].value;
                             var xxx = atValue.replace("pii:Bpiinumber#","").replace (" ", " ")
                              for(var attValue = 0; attValue < PrjAttr3.length; attValue++)
                                  var finalValue = "pii:"+ PrjAttr1[attValue] + "#" + PrjAttr2[attValue];
                                  if((PrjAttr3[attValue].localeCompare (xxx) == 0))
                                      var atValue = elm.xmlElements[i].xmlAttributes[j].value = String(finalValue);
              mySqrtTag(elm.xmlElements[i]);
      function traverse(tree)
                 //   alert("Inside the traverse");
                   myEveryName.push(tree.name());
                   myEveryContent.push(tree.text());// you get the contents by using .text() insted of .name()
                   myEveryAttributes.push(tree.attributes());
                    if(tree.elements().length() > 0)
                           for(var iroots=0; iroots<tree.elements().length(); iroots++)
                                    traverse(tree.elements()[iroots]);
