9 Replies Latest reply on Nov 27, 2015 9:33 AM by tpk1982
    Replace color via swatches
    tpk1982 Level 4
      I just need to find objects, texts or anything in page have spot color value of C=0 M=0 Y=0 K=100 into "Black" color.
      The below is the tried coding, it is not finding  "Black" color in swatch list.
      var doc = app.activeDocument;
      var item = doc.pageItems;
      var col = doc.swatches.getByName('Black');
      for(var i=0; i<item.length; i++){
               if(item[i].fillColor.spot.color.cyan == 0 && item[i].fillColor.spot.color.magenta == 0 && item[i].fillColor.spot.color.yellow == 0 && item[i].fillColor.spot.color.black == 100){
                      item[i].fillColor.spot.color == col;}     }
      Not sure why it is not applying. It is doing fine if the color is in process mode.
      if(item[i].fillColor.cyan == 0 && item[i].fillColor.magenta == 0 && item[i].fillColor.yellow == 0 && item[i].fillColor.black == 100){
                   item[i].fillColor == col;}
      Karthi
        • 1. Re: Replace color via swatches
          Qwertyfly... Level 4
          a process color does not have the spot variable/object in it. This will error.
          have a go at fillColor.typename
          if typename == "spot" seach the spot object else if typename == "CMYK" search as you have for process.
          nnot sure I have that 100% correct as I can't test it right now. run an alert on typename to double check I have the strings correct.
          • 2. Re: Replace color via swatches
            Vinicius Baptista Level 2
            Hi, try the code below:
            //function to verify that the black color there is
            var changeColor = function(){
            var col = doc.swatches["Black"].color;
            //If doesn't exist then set value to ""
            try{changeColor ()}
            catch(e){
                col = "";
            //If value is "" then create the swatche Black
            if (col == ""){
                var col = doc.swatches.add();
                col.Color = CMYKColor;
                col.name = "Black";
                col.cyan = 0;
                col.magenta = 0;
                col.yellow = 0;
                col.black = 100;
            //Apply the Black color to all spots with color is C=0 Y=0 M=0 K=100
                            item[i].fillColor = doc.swatches["Black"].color;
            I think it's what you want to do.
            I hope this will be useful.
            Best regards
            -Vinicius
            • 3. Re: Replace color via swatches
              tpk1982 Level 4
              Hi Vinicius,
              Thanks for your time. Your script working fine for fill color. I tried the same as stroke color. It throws error. I just tried another method. Finding k-100 value from swatch and apply with "Black". Please see the below tried codings and let me know your opinion.
              var docRef=app.activeDocument;
              for(i=0;i<docRef.swatches.length;i++){
                  var currSwatch=docRef.swatches[i];
                      if(currSwatch.color.typename=="SpotColor"){
                          var fillColor = currSwatch.color;
                          if (isSpotColorBlack (fillColor) && currSwatch.name!="Black") {
                              currSwatch.remove();
                  else if(currSwatch.color.typename=="CMYKColor"){
                              if (isColorBlack (fillColor) && currSwatch.name!="Black") {
                   function isColorBlack (cmykColor) {
                      var c = Math.round(cmykColor.cyan);
                      var m = Math.round(cmykColor.magenta);
                      var y = Math.round(cmykColor.yellow);
                      var k = Math.round(cmykColor.black);
                      if (c==0 && m==0 && y==0 && k == 100)
                          return true
                      else
                          return false  }
                  function isSpotColorBlack (spotColor) {
                      var c = Math.round(spotColor.spot.color.cyan);
                      var m = Math.round(spotColor.spot.color.magenta);
                      var y = Math.round(spotColor.spot.color.yellow);
                      var k = Math.round(spotColor.spot.color.black);
                          return true
                      else
                          return false  }
              Karthi
              • 4. Re: Replace color via swatches
                Hummm
                I did some tests and not getting any errors, please see the video below:
                https://www.sendspace.com/file/wl38j8
                Please, can you let me know what's your returned error?
                Tks, see ya,
                -Vinicius
                • 5. Re: Replace color via swatches
                  tpk1982 Level 4
                  Hi Vinicius,
                  The videos shows you tried with my codings. The error where i get is from your coding.
                  try{changeColor ()}
                  catch(e){
                      col = "";
                  if (col == ""){
                      col.name = "Black";
                      col.cyan = 0;
                      col.magenta = 0;
                      col.yellow = 0;
                      col.black = 100;
                  I changed line 32 as
                           if(item[i].strokeColor.spot.color.cyan == 0 && item[i].strokeColor.spot.color.magenta == 0 && item[i].strokeColor.spot.color.yellow == 0 && item[i].strokeColor.spot.color.black == 100){
                                  item[i].strokeColor = doc.swatches["Black"].color;
                  This is not working.
                  Regards,
                  Karthi
                  • 6. Re: Replace color via swatches
                    Hi Karthi,
                    Oh, my mistake, I think it's happening because you perform the code when the strokeColor of the item isn't a SpotColor, try verify it before, using a "If" structure like this:
                        if(item[i].strokeColor.typename == "SpotColor"){
                    Maybe it's work!
                    Regards,
                    -Vinicius
                    • 7. Re: Replace color via swatches
                      tpk1982 Level 4
                      Hi Vinicius,
                      Awesome...... Yes it is working for both fill and stroke spot color
                      For process color  stroke i need to change like below?
                      into
                      if(item[i].strokeColor.typename == "CMYKColor"), isn't it?
                      Regards,
                      Karthi
                      • 8. Re: Replace color via swatches
                        You are welcome Karthi, and yes you are right, to work with Process you need use "CMYKColor" and don't forget changing this line:
                        to
                        item[i].strokeColor.cyan == 0
                        Regards,
                        -Vinicius
                        • 9. Re: Replace color via swatches
                          tpk1982 Level 4
                          Hi Vinicius,
                          Yes, i keep that in mind.
                          THANK FOR YOUR TIME AND HELP.
                          Regards,
                          Karthi
