3 Replies Latest reply on Nov 30, 2015 12:43 AM by guyr5737163
    How do I print selected graphic in DC?
    guyr5737163
      Where has the 'Print selected graphic' option gone in DC?
        • 1. Re: How do I print selected graphic in DC?
          CtDave Level 5
          Something to try -- use the marquee zoom tool to select the object - do the file / print and in the print dialog select the desired printer. Next select  "Selected" (or phrase to that effect) to print only what you had selected.
          Be well...
          • 2. Re: How do I print selected graphic in DC?
            guyr5737163 Level 1
            Thanks but... that's my point... in DC, the 'Selected graphic' option appears to have gone.
            I don't want to marquee zoom and print view because I only want what is in the selection printed (and the selection is rarely going to be the same shape as the screen).
            At the moment, I have to take a snapshot and paste in Word, for example, and then print from there... just takes time
            This is a backward step if it has been removed.
            • 3. Re: How do I print selected graphic in DC?
              guyr5737163 Level 1
              Problem solved...
              If you use the select tool (arrow) to select a portion of the page and then right-click to 'Take a snapshot', there is no option to 'Print selected graphic'...
              But, using the 'Take a snapshot' tool does give the option to 'Print selected graphic'.
              Now I have the 'Take a snapshot' tool added to the toolbar, it's much better...
              It would be good if there was the option on the right-click with the arrow to 'Take snapshot and copy select graphic'
