1 Reply Latest reply on Nov 27, 2015 4:16 PM by Peter Spier
    al copiar texto entre dos documentos de indesign no conserva los estilos asignados
    agustinh78620713
      He asignado estilos de caracter y de párrafo a un texto en un documento de InDesign, copio este texto para llevarlo a otro documento, pego el texto en el nuevo documento y en este no me respeta las características de texto asignadas.
        • 1. Re: al copiar texto entre dos documentos de indesign no conserva los estilos asignados
          Normally this would only happen if the receiving document has styles with the same name and different definitions or styles with the same name and different definitions for styles upon which your transferred styles are based. Definitions in the receiving document are always used in such cases.
          We have seen, though, a case this week where a CS3 file opened in CC 2015 reverted to Times when text frames were copied with styles based on No Paragraph Style. The cure was to export as IDML, edit the styles, and save as a new .indd.
