4 Replies Latest reply on Nov 28, 2015 11:55 AM by paul8f
    Number of CPU cores needed (Virtual vs Physical) for 4K Premier video editing?
    paul8f
      Hi all.
      About to start up my own video editing service/business. I'm doing a custom build PC. I'm considering a dual Xeon processor motherboard with maybe 64GB of RAM and a certified Quadro 4GB or 8GB GPU. The 4k advertisements I plan to work on will be under 15mins long, using an average of 3 video tracks and 2 audio tracks.
      When it comes to running Adobe Premier Pro 5.5 or 6 (for 4K video editing and rendering), I've read that it's recommended to have 12 cores in each of the two processors. (The PDF document I read was an official 2015 guide from Intel:  "Hardware Performance Guide: Serious 4K Editing"
      Now, I'm wondering if this quoted figure of 12 cores per CPU is relating to PHYSICAL cores, or to ALL cores including VIRTUAL cores (...if it's referring to all cores then I just need to buy two 6 core processors giving a total of 24 usable cores.) Big price difference between a 6 core CPU and a 12 core....
      The Xeon series that will be compatible with my MB is the 2600 series CPU from the E5 v3 family. Any advice or horror stories much appreciated...!
      Paul.
        • 1. Re: Number of CPU cores needed (Virtual vs Physical) for 4K Premier video editing?
          RoninEdits Most Valuable Participant
          the intel guide is probably suggesting 12 actual cores, possibly the E5-2680 v3. so with dual xeon it would be 24 cores/48 virtual.
          adobe's software doesn't need the features on the quadro's, so using the nvidia gtx desktop/gaming version can help save money.
          if you need 10bit out for color correction, display out cards from mfg's like blackmagic, aja, and others can be a better option.
          have you already purchased the motherboard?
          hardware requirements will vary for different media types and project setups like multi-cam. codecs like h264/5 are very difficult for the cpu to process and the gpu should be handling it, but premiere doesn't currently support gpu accelerated decoding/encoding. that is what can lead to needing dual xeons as intel recommends. dual cpu's also have a large overhead, which reduces their combined processing power. another reason why intel may recommend the dual 12 core cpu's. if you are using less demanding codecs like prores or dnxhr, the cpu's wont have to be as powerful and may even be possible to use one cpu. some people transcode their footage from difficult codecs like h264/5 to prores or dnxhr as a work around instead of buying a more powerful system to handle h264/5 while editing.
          Tweakers Page - Video Codecs
          from Intel's pdf: "Hardware Performance Guide: Serious 4K Editing"
          It's important to note that software engineers must write specific code to take advantage of some features like multiple cores (multithreading) and virtual cores (hyper-threading). Mainstream applications like Adobe Premiere Pro and Adobe After Effects already take full advantage of these features.
          if you check the testing done here: Tweakers Page - Deciding between a single CPU or dual CPU  and read thru the threads here and other websites, you will find results contrary to that last sentence. adobe's software has long had problems fully multi-threading, premiere isn't as bad as some of adobe's other programs, but can still have problems.
          • 2. Re: Number of CPU cores needed (Virtual vs Physical) for 4K Premier video editing?
            Bill Gehrke Most Valuable Participant
            First of all we need to know what 4K media you will be editing.  Some of the more recent 4K media cannot be edited with CS5.5 or CS6.  Example Sony's professional XAVC high end cameras at up to 600 Mbits/sec will not be editable unless you upgrade to CC.  While the Sony consumer 4k cameras use XAVC S up to 100 Mbits/s and this is editable in CS6, I am doing it on a CS6 laptop.
            • 3. Re: Number of CPU cores needed (Virtual vs Physical) for 4K Premier video editing?
              paul8f Level 1
              Thanks for advice. I'm still not sure if I'm going to go with Adobe; there is also some very good software from Avid and Sony, and a Quadro card is designed and qualified for 24/7 use (which I may need in the future, if all goes well...). I've yet to purchase any parts, so I'll check up on Blackmagic cards.
              I think you may be right in saying that the quoted figure of 12 cores is related to physical cores. I'm guessing the PDF would have stated total cores if it meant to include virtual cores.
              Thanks as well for the heads-up on using dual CPUs. I had a sneaky suspicion that you wouldn't quite get double the computing power, and after reading that article you linked, I can see how a high-core E5 would be absolutely wasted on a lot of Adobe's offerings.
              • 4. Re: Number of CPU cores needed (Virtual vs Physical) for 4K Premier video editing?
                paul8f Level 1
                Cheers for info Bill. Starting off most of the work I plan to do will involve consumer grade footage, but in the future if all goes according to plan, I will be in the 'Prosumer' bracket. (Hope I'm using the correct word there...)
