For my Interactive Authoring III class, I created a matching game.
The problem is the timer. It counts down fine but the numbers are not being "reset" properly and when the numbers are changing it is re-writing over itself.
9 doesn't go away and 8 is printed over it, and then 7 is printed over it and so on.
Here is the code that deals with the timer:
// set up the clock
count = 180;
var gameTimer:Timer = new Timer(1000,count);
gameTimer.addEventListener(TimerEvent.TIMER, updateTime);
gameTimer.addEventListener(TimerEvent.TIMER_COMPLETE, timeExpired)
gameTimer.start();
function updateTime(e:TimerEvent):void {
// your class variable tracking each second,
count--;
gameTimeField = new TextField();
gameTimeField.x = 0;
gameTimeField.y = 200;
gameTimeField.embedFonts = true;
gameTimeField.autoSize = TextFieldAutoSize.LEFT;
gameTimeField.defaultTextFormat = digitalFormat;
addChild(gameTimeField);
gameTimeField.text = String("Time: "+ ((count)-gameTimer.currentCount));
function timeExpired(e:TimerEvent):void {
var gameTimer:Timer = e.target as Timer;
gameTimer.removeEventListener(TimerEvent.TIMER, updateTime)
gameTimer.removeEventListener(TimerEvent.TIMER, timeExpired)
MovieClip(root).gotoAndStop("gameoverAshton");
If you want to look at the actual files, the code is in each .as files for each player for each level. Example: Level1Ashton.as
Line 90
If somebody that is good with Action Script coding could take a look at it, I would really appreciate it.
Edith
You should use one text field only you don't need to create a new text field each time:
addChild(gameTimeField); // all the previous lines should be out of the timer function.
count--;
EDIT
