2 Replies Latest reply on Feb 16, 2009 12:57 AM by Michael Thornburgh
    Mobility details
    FredzCode
      Hi, in the documentation on Status, I've read that some support is implemented for wifi mobility issues, like a connection dropping for a moment.
      Can we have a bit more information on what happens when the "Mobility" features are working and what it does. (Does the nearID change, does the NetConnection fire events, and does it auto-reconnect ? :)
      Thanks in advance.
        • 1. Re: Mobility details
          Michael Thornburgh Adobe Employee
          in the "connection dropping for a moment" case, RTMFP caps retransmission timers to values reasonable for real-time communications, so when connectivity is restored, it doesn't take as long as TCP potentially would to notice. combined with partially reliable transmission of audio (when using Speex live and unbuffered), backlogs of data during the connectivity outage can be discarded, making your communication resume more quickly and keeping it more timely.
          in addition, in many cases RTMFP can keep a session up when one end changes IP addresses. this can happen in many normal circumstances, such as when you switch from a wireless connection to wired, or if a wireless base station (or other NAT device) restarts or times out your translation, or if you are moving between wireless base stations connected to different networks or providers. in this case, the session never goes down, so your nearID doesn't change and there is no reconnection. at the current time, there are no events to tell you that this has happened. the IP address mobility function can't always recover a session (typically when certain kinds of firewalls or NATs are in the middle), but it can recover in many cases, and in way more than the zero cases that TCP handles. :)
          -mike
          • 2. Re: Mobility details
            to clarify about IP address mobility: an RTMFP connection to a server (such as Adobe Stratus) will almost certainly survive any address change, but peer-to-peer connections may not always survive depending on the NATs and firewalls between the peers.
            also, only one end of an RTMFP session can change its address at a time. if both ends change addresses simultaneously, neither will be able to find the other anymore. however, both ends should still retain their connections to the server, so they would be able to re-establish their peer-to-peer connection again after the original one times out.
            -mike
