7 Replies Latest reply on Nov 28, 2015 7:06 PM by johnrellis
    Stack counts not visible in filmstrip
    jwArtWorks Level 1
      For some reason, my virtual copy stack counts do not appear in the filmstrip. I checked the filmstrip view options and "Show Stack Counts" is checked!
        • 1. Re: Stack counts not visible in filmstrip
          johnrellis Most Valuable Participant
          You likely have the filmstrip set to be too small -- see this article for how to make it bigger: Lightroom Filmstrip Tips | Laura Shoe's Lightroom Training, Tutorials and Tips
          • 2. Re: Stack counts not visible in filmstrip
            jwArtWorks Level 1
            Great thought but I made them huge and still no stack info!!!
            One more thing I noticed. The buttons for target collection do not work in the filmstrip either. They work in Library Grid mode on the grid but not the filmstrip. If I right-click and add to target collection, it works fine.
            • 3. Re: Stack counts not visible in filmstrip
              In Library grid mode, do the photos appear stacked?  LR is weird when it comes to stacking.  If you stacked the photos in a folder, the stacking won't show up when you've selected a collection containing the photos as a source.  Conversely, if you've stacked the photos in a collection, the stacking won't show up when you select a folder or All Photographs as the source.
              If this doesn't help, please post a full-resolutions screenshot of your LR window.  (You need to come back to the Web to do that -- you can't send it as an email attachment.)
              • 4. Re: Stack counts not visible in filmstrip
                Just Shoot Me Adobe Community Professional
                I was just going to post the same info as above. Stacked in a folder, no stacking showing in a collection of the same images. When selecting the the keyword for those same images that are in a collection the stacking shows.
                • 5. Re: Stack counts not visible in filmstrip
                  jwArtWorks Level 1
                  This is a troublesome issue that really needs some resolution. If there are stacked images, they need to show all the time!!!
                  Thanks john, for your insight.
                  Thanks shootistbond007 for the same info!
                  • 6. Re: Stack counts not visible in filmstrip
                    The only time it doesn't show the stack count is in a collection and that collection is selected. It then it shows All the Images in that collection. If they were stacked from being sent/edited in PS then it has a different file extension. If they are Virtual Copies then is has the turned down corner with the same file name.
                    This seems logical to me. In fact IIRC a virtual copy or an Edited image isn't added to a collection unless you specifically add it.
                    • 7. Re: Stack counts not visible in filmstrip
                      Unfortunately, Adobe thought differently when they changed the way stacks work in LR 4.  It's a weird design, and I've never seen a justification for it.  But stacks you make in folders aren't visible when you are working in a collection, and stacks you make in a collection aren't visible when you're working in a folder.
                      You could add your vote and detailed opinion to this topic in the official Adobe feedback forum: Lightroom: Stacks should be first-class citizens. That might make it (a little) more likely that Adobe might eventually change the behavior of stacks.  But don't hold your breath -- people have been complaining for five years.
