9 Replies Latest reply on Apr 28, 2016 7:07 PM by ralphp34572065
    iPhoto import fails with 'Oops! An untagged string' error message
    ewenjc
      I'm trying to help a friend import his iPhoto library into Lightroom and it's failing with the following message: 'Oops! An untagged string (?:0: attempt to index a nil value) got thrown far enough that we display it to the user. This shouldn't happen.'  It gave this error on his machine and just reproduced the same error on my setup.  The import is into a new empty catalog.
      Anyone got any ideas on what might be causing this?
      Any suggestions would be very welcome,
      -Ewen
      The full console log is;
      Nov 29 09:20:39 Ewens-iMac.local Adobe Photoshop Lightroom 5[1957]: Cannot add package named WFCoreTests
        Looked in /Applications/Adobe Photoshop Lightroom 5.app/Contents/Frameworks/WichitaFoundation.agtoolkit/Versions/A/Frameworks/WFCoreTests.f ramework, /Applications/Adobe Photoshop Lightroom 5.app/WFCoreTests.framework, /Applications/Adobe Photoshop Lightroom 5.app/Contents/Frameworks/WFCoreTests.framework, /Applications/Adobe Photoshop Lightroom 5.app/Contents/Frameworks/WichitaFoundation.agtoolkit/Versions/A/Frameworks/WFCoreTests.a gtoolkit, /Applications/Adobe Photoshop Lightroom 5.app/WFCoreTests.agtoolkit, /Applications/Adobe Photoshop Lightroom 5.app/Contents/Frameworks/WFCoreTests.agtoolkit
      Nov 29 09:20:39 Ewens-iMac.local Adobe Photoshop Lightroom 5[1957]: Cannot add package named WFSQLiteTests
        Looked in /Applications/Adobe Photoshop Lightroom 5.app/Contents/Frameworks/WichitaFoundation.agtoolkit/Versions/A/Frameworks/WFSQLiteTests .framework, /Applications/Adobe Photoshop Lightroom 5.app/WFSQLiteTests.framework, /Applications/Adobe Photoshop Lightroom 5.app/Contents/Frameworks/WFSQLiteTests.framework, /Applications/Adobe Photoshop Lightroom 5.app/Contents/Frameworks/WichitaFoundation.agtoolkit/Versions/A/Frameworks/WFSQLiteTests .agtoolkit, /Applications/Adobe Photoshop Lightroom 5.app/WFSQLiteTests.agtoolkit, /Applications/Adobe Photoshop Lightroom 5.app/Contents/Frameworks/WFSQLiteTests.agtoolkit
      Nov 29 09:20:39 Ewens-iMac.local Adobe Photoshop Lightroom 5[1957]: Cannot add package named WFWebTests
        Looked in /Applications/Adobe Photoshop Lightroom 5.app/Contents/Frameworks/WichitaFoundation.agtoolkit/Versions/A/Frameworks/WFWebTests.fr amework, /Applications/Adobe Photoshop Lightroom 5.app/WFWebTests.framework, /Applications/Adobe Photoshop Lightroom 5.app/Contents/Frameworks/WFWebTests.framework, /Applications/Adobe Photoshop Lightroom 5.app/Contents/Frameworks/WichitaFoundation.agtoolkit/Versions/A/Frameworks/WFWebTests.ag toolkit, /Applications/Adobe Photoshop Lightroom 5.app/WFWebTests.agtoolkit, /Applications/Adobe Photoshop Lightroom 5.app/Contents/Frameworks/WFWebTests.agtoolkit
      Nov 29 09:20:39 Ewens-iMac.local Adobe Photoshop Lightroom 5[1957]: Cannot add package named WFOzClientTests
        Looked in /Applications/Adobe Photoshop Lightroom 5.app/Contents/Frameworks/WichitaFoundation.agtoolkit/Versions/A/Frameworks/WFOzClientTes ts.framework, /Applications/Adobe Photoshop Lightroom 5.app/WFOzClientTests.framework, /Applications/Adobe Photoshop Lightroom 5.app/Contents/Frameworks/WFOzClientTests.framework, /Applications/Adobe Photoshop Lightroom 5.app/Contents/Frameworks/WichitaFoundation.agtoolkit/Versions/A/Frameworks/WFOzClientTes ts.agtoolkit, /Applications/Adobe Photoshop Lightroom 5.app/WFOzClientTests.agtoolkit, /Applications/Adobe Photoshop Lightroom 5.app/Contents/Frameworks/WFOzClientTests.agtoolkit
      Nov 29 09:20:51 Ewens-iMac Adobe Photoshop Lightroom 5[1957]: assertion failed: 14F27: libxpc.dylib + 62447 [5C829202-962E-3744-8B50-00D38CC88E84]: 0x89
      Nov 29 09:20:56 Ewens-iMac.local Adobe Photoshop Lightroom 5[1957]: WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.5 instead of 10.10.5. Use NSProcessInfo's operatingSystemVersion property to get correct system version number.
      Nov 29 09:20:56 Ewens-iMac.local Adobe Photoshop Lightroom 5[1957]: 0   CarbonCore                          0x00007fff90e752b7 ___Gestalt_SystemVersion_block_invoke + 113
      Nov 29 09:20:56 Ewens-iMac.local Adobe Photoshop Lightroom 5[1957]: 1   libdispatch.dylib                   0x00007fff8aacbc13 _dispatch_client_callout + 8
      Nov 29 09:20:56 Ewens-iMac.local Adobe Photoshop Lightroom 5[1957]: 2   libdispatch.dylib                   0x00007fff8aacbb26 dispatch_once_f + 117
      Nov 29 09:20:56 Ewens-iMac.local Adobe Photoshop Lightroom 5[1957]: 3   CarbonCore                          0x00007fff90dfe456 _Gestalt_SystemVersion + 987
      Nov 29 09:20:56 Ewens-iMac.local Adobe Photoshop Lightroom 5[1957]: 4   CarbonCore                          0x00007fff90dfd6e3 Gestalt + 144
      Nov 29 09:20:56 Ewens-iMac.local Adobe Photoshop Lightroom 5[1957]: 5   AgSubstrate                         0x0000000101285559 AgUtils_SystemVersion + 31
      Nov 29 09:20:56 Ewens-iMac.local Adobe Photoshop Lightroom 5[1957]: 6   AgUI                                0x00000001011d9fd7 AgColorUtils_sampleScreen_L + 5989
      Nov 29 09:21:00 Ewens-iMac.local WindowServer[170]: disable_update_timeout: UI updates were forcibly disabled by application "Lightroom" for over 1.00 seconds. Server has re-enabled them.
      Nov 29 09:21:00 Ewens-iMac.local WindowServer[170]: common_reenable_update: UI updates were finally reenabled by application "Lightroom" after 1.07 seconds (server forcibly re-enabled them after 1.00 seconds)
      Nov 29 09:21:22 Ewens-iMac.local Adobe Photoshop Lightroom 5[1957]: Unable to simultaneously satisfy constraints:
      Nov 29 09:28:54 Ewens-iMac.local Adobe Photoshop Lightroom 5[1957]: Unable to simultaneously satisfy constraints:
      Nov 29 09:29:22 Ewens-iMac.local Adobe Photoshop Lightroom 5[1957]: Unable to simultaneously satisfy constraints:
      Nov 29 09:30:26 Ewens-iMac.local Adobe Photoshop Lightroom 5[1957]: Oops! An untagged string (?:0: attempt to index a nil value) got thrown far enough that we display it to the user. This shouldn't happen.
