1 Reply Latest reply on Feb 17, 2009 11:02 AM by Newsgroup_User
    Flash element - change pointer from arrow to hand in Director
    rafa@mediatech Level 1
      Hi everyone,
      I build a pop-up box in flash that I want to use in Director. It is sort of a tab, that hides in a corner of the screen and when the user rolls over it, it slides out showing some buttons. How can I tell director to change the pointer into a hand when the user rolls over the buttons inside my flash element (not when it rolls on the tab itself)? Also, can I code these buttons to open PDF documents from Director, even thou it was made in flash... if so, how?
      Thank you for your help!
      Rafael.
        • 1. Re: Flash element - change pointer from arrow to hand in   Director
          Level 7
          Check the docs for 'hitTest' and/or 'mouseOverButton', or alter the
          Flash file so that it tells Director to change the cursor whn appropriate.
          Either use 'setCallback', or add some AS to your Flash file telling
          Director what to do.
          getURL("lingo: mHandler");
          will call the handler #mHandler in a #movie script, while
          getURL("event: mHandler);
          will call the handler #mHandler in a score script attached to the Flash
          sprite
