Hi there, I have worked on a number of CMSs before and am very familiar with Adobe Creative Suite products but am a little lost while trying to do something very simple.
So, I need to remove some of the pages from the website, I have located the page files and can see that if I disable/enable pages they do as they are told. Simple.
BUT if I go into "menus" there is no corresponding main menu, well let's say one of them actually does correspond and has different menu item names than the actual menu, which I suppose could be feasible given how unfamiliar I am, if I disable/enable menu items by the same method I disabled/enabled pages it does absolutely nothing. I would assume by logic that the main menu items should be sitting under "menus".
Can anyone please shed some light as to what I'm missing here. Let me know if screen shots will.
Thanks in advance...
Hello,
It is very possible that the main menu is hard coded into the template file that you are using for your website.
Please have a look there by going to Site Manager -> Page Template -> the default template.
If you need additional help please share the site that you are referring to so I can have a closer look.
Stoiky
