2 Replies Latest reply on Nov 30, 2015 10:01 PM by Gaurav Bhargava
    Data Merge Crash inDesign CC 2015 ( 11.1.0.122 )
    eoghan calnan
      One page document open in inDesign.
      9 lines of data in a CSV file.
      Preview works absolutely fine...
      Crashes the instant I click "Export to PDF" or "Create Merged Document"
      I tried the fixes for 9.2 (Cleared the cache and preferences file in my library.)
      Dump with all my system details:
      Process:               Adobe InDesign CC 2015 [7724]
      Path:                  /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Adobe InDesign CC 2015
      Identifier:            com.adobe.InDesign
      Version:               11.1.0.122 (11100)
      Code Type:             X86-64 (Native)
      Parent Process:        ??? [1]
      Responsible:           Adobe InDesign CC 2015 [7724]
      User ID:               501
      Date/Time:             2015-11-30 14:13:40.528 +0000
      OS Version:            Mac OS X 10.11 (15A284)
      Report Version:        11
      Anonymous UUID:        A9750705-B0A6-52C4-11A3-2D4C2A77080E
      Time Awake Since Boot: 13000 seconds
      System Integrity Protection: enabled
      Crashed Thread:        0  Dispatch queue: com.apple.main-thread
      Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
      Exception Codes:       KERN_INVALID_ADDRESS at 0x0000000000000000
      Exception Note:        EXC_CORPSE_NOTIFY
      VM Regions Near 0:
          __TEXT                 0000000108131000-0000000108136000 [   20K] r-x/rwx SM=COW  /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Adobe InDesign CC 2015
      Global Trace Buffer (reverse chronological seconds):
      227.042953   CFNetwork                 0x00007fff92af407b TCP Conn 0x7f9b380a8d20 SSL Handshake DONE
      227.173975   CFNetwork                 0x00007fff92af3f57 TCP Conn 0x7f9b380a8d20 starting SSL negotiation
      227.174075   CFNetwork                 0x00007fff92af2927 TCP Conn 0x7f9b380a8d20 complete. fd: 14, err: 0
      227.174562   CFNetwork                 0x00007fff92b81121 TCP Conn 0x7f9b380a8d20 event 1. err: 0
      227.302267   CFNetwork                 0x00007fff92af1bf7 TCP Conn 0x7f9b380a8d20 started
      233.868931   CFNetwork                 0x00007fff92af407b TCP Conn 0x7f9b2ff09170 SSL Handshake DONE
      Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
      0   com.adobe.InDesign.DataMerge   0x0000000114dcb145 0x114dbd000 + 57669
      1   com.adobe.InDesign.DataMergeUI 0x0000000114e9512c 0x114e7f000 + 90412
      2   WidgetBinLib.dylib             0x00000001083f1e47 CDialogController::InitializeDialog(IActiveContext*) + 71
      3   WidgetBinLib.dylib             0x00000001083f4f26 CSelectableDialogSwitcher::InitializePanel() + 230
      4   WidgetBinLib.dylib             0x00000001083f524b CSelectableDialogSwitcher::SwitchDialogPanel(int, short) + 619
      5   WidgetBinLib.dylib             0x00000001083f54d8 CSelectableDialogSwitcher::SwitchDialogPanelByID(IDType<WidgetID_tag>) + 392
      6   com.adobe.InDesign.DataMergeUI 0x0000000114e83498 0x114e7f000 + 17560
      7   com.adobe.InDesign.DataMergeUI 0x0000000114e81c94 0x114e7f000 + 11412
      8   com.adobe.InDesign.Actions     0x0000000117150a98 0x11713b000 + 88728
      9   com.adobe.InDesign.DataMergeUI 0x0000000114ea10ac 0x114e7f000 + 139436
      10  com.adobe.InDesign.AppFramework 0x00000001171da400 0x1171ab000 + 193536
      11  com.adobe.InDesign.AppFramework 0x00000001171d976c 0x1171ab000 + 190316
      12  PublicLib.dylib               0x000000010965f6a1 CSubject::Change(IDType<ClassID_tag>, IDType<PMIID_tag> const&, void*) + 81
      13  com.adobe.InDesign.DV_Widgets 0x000000011856e03a 0x118568000 + 24634
      14  com.adobe.InDesign.DV_Widgets 0x000000011856eba3 0x118568000 + 27555
      15  com.adobe.InDesign.DV_Widgets 0x000000011856ec82 0x118568000 + 27778
      16  DV_WidgetBinLib.dylib         0x0000000108191a1c DVIconSuiteButtonView::ChangeControls(short) + 76
      17  DV_WidgetBinLib.dylib         0x0000000108193561 0x108168000 + 177505
      18  com.adobe.dvaui.framework     0x0000000108c33a97 dvaui::controls::UI_ControlView::SendControlMessages(dvacore::utility::SharedFunctions<bo ost::shared_ptr<boost::function<void (dvaui::ui::MessageT<dvaui::ui::UI_Node>*)> > > const&, dvaui::ui::MessageT<dvaui::ui::UI_Node>*) + 71
      19  com.adobe.dvaui.framework     0x0000000108c00fba dvaui::controls::UI_Button::SendButtonChangedMessage(dvacore::utility::Flags<unsigned char>) + 186
      20  com.adobe.dvaui.framework     0x0000000108c0012c dvaui::controls::UI_Button::PerformAction(bool, dvacore::utility::Flags<unsigned char>, bool) + 108
      21  com.adobe.dvaui.framework     0x0000000108c00b0a dvaui::controls::ButtonInputCapture::End() + 154
      22  com.adobe.dvaui.framework     0x0000000108e7c82f dvaui::ui::PointerCapture::InvokeEnd(bool) + 143
      23  com.adobe.dvaui.framework     0x0000000108e87868 dvaui::ui::UI_NodeManager::EndInputCapture(bool) + 104
      24  com.adobe.dvaui.framework     0x0000000108c00caf dvaui::controls::ButtonInputCapture::DoMouseEvent(dvaui::ui::MouseEvent const&) + 255
      25  com.adobe.dvaui.framework     0x0000000108e93106 dvaui::ui::UI_Node::UI_DispatchCapturedMouseEvent(dvaui::ui::MouseEvent const&) + 438
      26  com.adobe.dvaui.framework     0x0000000108e9299f dvaui::ui::UI_Node::UI_DispatchPointerEventToTarget(dvaui::ui::UI_Node*, dvaui::ui::PointerEvent const&, bool) + 159
      27  com.adobe.dvaui.framework     0x0000000108e92852 dvaui::ui::UI_Node::UI_DispatchPointerEvent(dvaui::ui::PointerEvent const&, bool) + 66
      28  com.adobe.dvaui.framework     0x0000000108f17250 dvaui::ui::OS_View::UI_DispatchPlatformMouseEvent(dvaui::ui::MouseEvent const&, bool) + 608
      29  com.adobe.dvaui.framework     0x0000000108f16dde dvaui::ui::OS_View::UI_DispatchPlatformMouseClickEvent(dvaui::ui::OS_Event const&) + 606
      30  com.adobe.dvaui.framework     0x0000000108f15159 dvaui::ui::OS_View::UI_DispatchEvent(dvaui::ui::OS_Event*) + 121
      31  com.adobe.dvaui.framework     0x0000000108f150b6 dvaui::ui::OS_View::UI_HandleOSEvent(dvaui::ui::OS_Event*) + 22
      32  com.adobe.dvaui.framework     0x0000000108f16885 dvaui::ui::OS_View::UI_HandlePlatformEvent(NSEvent*) + 69
      33  com.adobe.dvacore.framework   0x0000000108846ebc int dvacore::config::ErrorManager::ExecuteFunction<void>(boost::function0<void>*, void*) + 28
      34  com.adobe.InDesign.Application UI 0x00000001175515c2 0x117412000 + 1308098
      35  com.adobe.dvacore.framework   0x0000000108847010 void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler<void>(boost::f unction0<void>, bool*) + 144
      36  com.adobe.dvacore.framework   0x0000000108848505 void dvacore::config::ExecuteTopLevelFunction<void>(boost::function0<void>, bool*) + 165
      37  com.adobe.dvaui.framework     0x0000000108f21f1a dvaui::ui::OS_NodeTimerData::RemoveTimer() + 29738
      38  com.apple.AppKit               0x00007fff99ae18bf -[NSWindow _handleMouseUpEvent:isDelayedEvent:] + 119
      39  com.apple.AppKit               0x00007fff99ae2559 -[NSWindow _reallySendEvent:isDelayedEvent:] + 212
      40  com.apple.AppKit               0x00007fff99527d31 -[NSWindow sendEvent:] + 517
      41  com.adobe.owl                 0x000000010861889d 0x1085dd000 + 243869
      42  com.apple.AppKit               0x00007fff994a7ccb -[NSApplication sendEvent:] + 2540
      43  com.adobe.dvaui.framework     0x0000000108f1aecb dvaui::ui::OS_NodeTimerData::RemoveTimer() + 987
      44  com.adobe.exo.framework       0x000000010abb098a exo::app::OS_AppBase::SetResetMenuShortcutsOnClose(bool) + 842
      45  DV_WidgetBinLib.dylib         0x0000000108202ca5 0x108168000 + 634021
      46  com.adobe.InDesign.Application UI 0x00000001175584ee 0x117412000 + 1336558
      47  com.apple.AppKit               0x00007fff9930ef3e -[NSApplication run] + 796
      48  com.adobe.exo.framework       0x000000010abb03b8 exo::app::OS_AppBase::RunEventLoop() + 56
      49  com.adobe.InDesign.AppFramework 0x00000001172f9463 0x1171ab000 + 1369187
      50  com.adobe.InDesign.AppFramework 0x00000001172f832c 0x1171ab000 + 1364780
      51  com.adobe.InDesign             0x000000010813268d main + 285
      52  libdyld.dylib                 0x00007fffa043a5ad start + 1
      [trimmed by moderator]
      Please Help!!
