2 Replies Latest reply on Dec 2, 2015 5:41 AM by kadel27
    Error: arithmetic over/underflow - Divided by zero?
    kadel27
      Hello,
      Im newbie on Adobe LiveCycle. Ive successfully create a form and now I wanted to put some calculating on it.
      Everything is fine, pdf is calculating, but Im getting an errors, because I understand that Im trying to calculate with the filed, those are empty - not inputed yet as a zero fields => divide by zero... ?
      May somebody please help me, how to write the formula to not get the errors?
      My actual formula is:
      pod11.rawValue = ( ( ( pod2.rawValue * ( pod8.rawValue / 100 ) ) - pod6.rawValue ) / pod2.rawValue ) * 100
      Thank You very much for the help!
      K.
        • 1. Re: Error: arithmetic over/underflow - Divided by zero?
          Magus069 Level 4
          Hi there,
          to prevent errors within calculate you should verify each fields to make sure there is no rawValue that is equal to null..
          if you are using formcalc, use "<>" or "ne" to specify not equal to
          if you are using javascript, use "!=" or "!==" to specify not equal to
          JavaScript
          if (pod2.rawValue != null && pod8.rawValue != null && pod6.rawValue != null){
                 pod11.rawValue = ( ( ( pod2.rawValue * ( pod8.rawValue / 100 ) ) - pod6.rawValue ) / pod2.rawValue ) * 100;
          } else{
                 pod11.rawValue = null;
          FormCalc
          if (pod2.rawValue <> null & pod8.rawValue <> null & pod6.rawValue <> null) then
          else
          endif
          Hope this will help!
          • 2. Re: Error: arithmetic over/underflow - Divided by zero?
            kadel27 Level 1
            THANKY YOU VERY MUCH!!!!
            You made my day! :)
