1 Reply Latest reply on Dec 1, 2015 12:57 PM by JimHess
    Lightroom "Exposure" vs "White"?
    joseph motto
      When going through my workflow I find that at times I go to "exposure" to lighten or darken certain images and at other times I use "white." There doesn't seem to be a logical pattern to follow.  I would be interested to hear how others approach this question, i.e., when do you use one, when the other, and when both?
        • 1. Re: Lightroom "Exposure" vs "White"?
          Adjusting exposure makes the adjustment to the entire image. When you are using the Whites adjustment you are making adjustments to only the whitest/brightest parts of your image. Also, using the White slider in conjunction with the alt/opt key enables you to set the appropriate white point for your image. Conversely using the Black slider this way can help you set the black point properly.
