1 Reply Latest reply on Dec 2, 2015 11:25 PM by Akash Sharma
    Upgrading from retail version of LR5 to 2015 CC
    peusdonym
      Hi and hello.
      I finally decided to pull the trigger to get the new Lightroom.
      However, I currently have a retail version of LR5 installed.
      Should I completely remove the current LR before install the new one?
      If I don't, will it be upgraded or both of them will co-exist in my computer?
      Same question goes to my Adobe Audition.
        • 1. Re: Upgrading from retail version of LR5 to 2015 CC
          Akash Sharma Adobe Employee
          Hi peusdonym
          When you will install Lightroom CC
          It will Prompt you to upgrade your catalog(only default) to Lightroom CC
          Simply Click Yes and you are done.
          Should I completely remove the current LR before install the new one?If I don't, will it be upgraded or both of them will co-exist in my computer?
          It is a good to have both the versions installed on your computer as both will have separate installs and catalogs
          If you have a Plenty of space on your Primary harddrive. Keep version 5 installed.
          If your computer is running low on space .You could safely uninstall it.
          Same scenario applies to Audition as well.It would be still best to ask a question on Audition CS5.5, CS6 & CC
          Regards
          Akash
