0 Replies Latest reply on Dec 3, 2015 8:28 AM by alliejamison
    Presenter 11 - drag&drop - map multiple drag items to a single drop item
      Hi there, it´s quite simple: The function mentioned in the title just doesn´t work. I cannot select a drop item in the pulldown menu. I see them but can´t select. Any Ideas?
      The Adobe help says:
      You can map multiple drag items to a single drop item. However, you have to add a separate row for each drag item and select the drop item correspondingly. For example, if A and B both have to be mapped to ‘alphabets’, the first row contains A (drag item) and ‘alphabets’ (drop item). The second row contains B (drag item) also mapped to ‘alphabets’ (drop item). Tip: Drop items that have already been added appear in the drop-down list for subsequent use
      Thanks in advance!
