5 Replies Latest reply on Dec 4, 2015 4:27 AM by Peter Spier
    InDesign Problems unsolved ?
      among us there is the following problem:
      InDesign documents these with ID CS5 were prepared, CS6 cannot be processed any more in ID.
      Falls away as soon as one opens these documents and tries to work on a text module copy move to or delete, ID "does not work with the report any more".
      Bs is Windows 7 32 bits.
      Problem signature:
      Problem event name: APPCRASH
      Application name: InDesign.exe
      Application version:
      Application time stamp: 4 f72c3ee
      Fault module name: TEXT.RPLN
      Fault module version:
      Fault module time stamp: 4f72c802
      Exception code: C0000005
      Exception offset: 0029202 c
      OS: 6.1.7601.
      Area scheme ID: 1031
      Additional user information 1: 0 a9e
      Additional user information 2: 0 a9e372d3b4ad19135b953a78882e789
      Additional user information 3: 0 a9e
      Additional user information 4: 0 a9e372d3b4ad19135b953a78882e789
      The Windows event viewer provides the following report: (German)
      One workaround consists in and in opening CS5 the files with ID in copying the contents into a new document.
      This file prepared newly then has on CS6 worked in ID for itself again
      Unfortunately crasht occasionally also spare the SW at the start.
      We have tested solutions like installation on a fresh system or moving back of the user profile data.
      The SW is update technical up-to-date.
      We would be happy if there are solution trials for these difficulties.
      Many thanks in advance.
      Yours faithfully
      Nicolas Ostwald
