2 Replies Latest reply on Nov 20, 2006 9:53 AM by ntsiii
    XML File Within XML File
    Meflex
      Hi everyone,
      Plz help me out.....
      Currently, I am working on flex and Remote Object Accessing. My problem is that, in my application I have one Servlet which writes .xml file in browser and I use that .xml file to display data in Datagrid. Everything was woking fine. But then I have to change my .xml file in such a way that one of it's node is a .xml file. like this...
      <?xml version="1.0" encoding="UTF-8" ?>
      - <root>
      - <detail>
      <server>SOA </server>
      <resp_time>250</resp_time>
      - <request>
      - <envelope>
      <operation>addition</operation>
      </envelope>
      </request>
      </detail>
      </root>
      Here request is one of the node in .xml file. now when i am displaying data in this file into datagrid, datagrid show correct data for <server> and <resp_time> tag. But it shows "[object Object]" for request tag.
      Can any one tell me how can I show that request node into my datagrid ,so that it shows me ..
      <request>
      - <envelope>
      </envelope>
      </request>
      instead of [object Object] ???? Please Hepl me
        • 1. Re: XML File Within XML File
          Meflex Level 1
          Tracy had replied me that you can use labelFunction. like this...
          private function lfRequest(oItem:Object, dgc:DataGridColumn):String
          return oItem.request.toXMLString()
          I have used resultHandler like this ....
          [Bindable]
          var xmlFile:String = null;
          private function resultHandler(event:ResultEvent):void
          trace("resultHandler is called...");
          var myO:Object = new Object();
          myO = event.result;
          trace("after new XML()");
          xmlFile=myO.request.toXMLString();
          trace("after toString()");
          and i m trying to display that ' xmlFile:String' into datagrid, but it gives me this runtime-error:
          Error #1009: Cannot access a property or method of a null object reference.
          then i tryed this...
          xmlFile=myO.request.root.detail.toXMLString(); then it gives me this error message :
          plz help me...
          • 2. Re: XML File Within XML File
            ntsiii Level 3
            First, make sure your resultFormat="e4x"
            Then in the handler, change to:
            var xmlResult:XML;
            xmlResult= XML(event.result);
            xmlFile=xmlResult.toXMLString();
            trace(xmlFile);
            Tracy
