2 Replies Latest reply on Aug 31, 2016 5:54 PM by MAMarcellino
    Adobe Flash Pro CS5 Eyedropper Tool issue on OS X El Capitan
    Aranx
      Hey guys
      I just installed an update to OSX which was(OS X El Capitan) and then I had to install Java for that version to be able to use Flash so I did that, but now my Flash Pro Cs5 seems to be messed up(Or the eyedropper tool) is messed up. Whenever I want to use it to copy a color it just gives me a random color, and not the color I want.. I am not sure if I have miss-clicked something in Flash which made it like this, or if it is actually because of OS X El Capitan. I hope someone can help me to get it back to normal.
      Also:
      - It seems like the Eyedropper only can get the colours from the (fill color) box.
      - When I click on the eyedropper or to get a color from a different image it just gives me a random color. When I move the mouse over something it just shows random colours in the box.
      - Aranx
        • 1. Re: Adobe Flash Pro CS5 Eyedropper Tool issue on OS X El Capitan
          sciffany
          Hi!
          I use OSX El Capitan Version 10.11.14, and I experienced the same problem with my Flash CS5.5.
          I found that you can get around this problem if you are working with your own graphics. Keep double clicking on the movie clip/graphic/object/group with the colour that you want to copy, until you find the source Shape that contains that colour.
          On the Properties window, you should see the Fill and Stroke of that Shape. The Fill property of the shape should be the colour you want to copy. If you save your file (Ctrl-S), you should notice that the Foreground Colour in the Toolbox changes into the Fill colour of the selected shape.
          Hope this works for you!
          • 2. Re: Adobe Flash Pro CS5 Eyedropper Tool issue on OS X El Capitan
            MAMarcellino
            I, too, am having the same exact issue as described with Flash Pro CS4. As many users have stated, this occurred immediately after updating to El Capitan (and also updating Java, although I don't know if that was related or not), so I have to assume this is a bug, but I'm not sure where to look for a solution at this point. Yes, there may be "work arounds" for this issue, but it is EXTREMELY annoying, especially when CS4 is quirky enough as it is! I have to imagine that this issue has been around for about a year now which is very discouraging... Does anyone have a solution yet that doesn't involve uninstalling El Capitan or upgrading to Animate CC?
