1 Reply Latest reply on Feb 11, 2009 7:55 PM by Newsgroup_User
    On beginsprite
    bmohnsen3
      If I have one cast member in channel 1 and I use an on beginsprite to determine its location.
      Then a few frames later I have a different cast member in channel 1 and I use an on beginsprite to determine its location.
      Will these two actions interfere with one another?
        • 1. Re: On beginsprite
          Level 7
          It depends on what you mean by "Then a few frames later I have a
          different cast member in channel 1"
          If you are only changing the member of the sprite (via lingo) then the
          beginSprite event will not be generated. On the other hand, if the
          sprite is truly ending and new sprite is instantiated then the
          beginSprite event will be generated, regardless of what it's member
          property is. These two beginSprite events will in no way interfere with
          each other.
          > its location.
