2 Replies Latest reply on Jan 9, 2009 12:43 PM by Jackal_Dude
    Settings Panel Position
    Jackal_Dude
      Does anyone know if there is a way to set the position of this panel somewhere on the stage? Any tricks or tips?
      Thanks.
        • 1. Re: Settings Panel Position
          Level 7
          Jackal_Dude,
          Your subject line mentions a Settings panel ... but I'm not sure which
          panel you mean. (There isn't a choice for "Settings" under the menubar's
          Window pull-down.) Do you mean the Property inspector? It's called
          Properties under the Window pull-down. In any case, what version of Flash
          are you using?
          David Stiller
          Adobe Community Expert
          Dev blog, http://www.quip.net/blog/
          "Luck is the residue of good design."
          • 2. Re: Settings Panel Position
            Jackal_Dude Level 1
            I was referring to the user's settings panel within a swf that can be displayed by the user right clicking and selecting "Settings" or programatically by using the actionscript "System.showSettings([id of panel])"
            I was curious if anyone has found a way to position that panel on the stage. I really need it to display in a specific location within the swf.
