2 Replies Latest reply on Dec 7, 2015 8:33 AM by graemem34292562
    Merge table cells based on paragraph style
    graemem34292562
      Hello
      I am new to InDesign scripting and have been searching the forum for script to merge table cells based on a paragraph style.
      I am using tables to import xml data into an Indesign document, which will be approx 250 pages. In the xml I am using "aid:pstyle" xml attributes to catch paragraph styling on the xml import as well as some cell styling to format tables. However, in some instances I want to use a script merge table cells horizontally create a 2 column row. The 2nd column on each row  to be merged has a paragraph style "tableBodyMere" and I am looking for a small javaScript solution to:
      1, Look at all tables in the document and find the paragraph style "tableBodyMerge" The table is 6 columns wide and  "tableBodyMerge" is always assigned to text on column 2 of each row.
      2, When "tableBodyMerge" is found conduct a cell merge from 6 columns to 2, starting from column 2. So the row ends up as a 2 column row.
      Before:
      After:
      Any assistance would be much appreciated
        • 1. Re: Merge table cells based on paragraph style
          Jump_Over Level 5
          A raw solution could be like this:
          var
            mColumns = app.activeDocument.stories.everyItem().tables.everyItem().columns[1].getElements(),
            cColumn, cCells, cCell;
            targetStyle = app.activeDocument.paragraphStyles.item("tableBodyMerge");
            while (cColumn = mColumns.shift()) {
                 cCells = cColumn.cells.everyItem().getElements();
                 while (cCell = cCells.shift()) {
                      if (cCell.insertionPoints[0].appliedParagraphStyle == targetStyle)
                           cCell.merge(cCell.parentRow.cells[-1]);
          Still open problem for above code:
               - what to do if further cell's contents exists (now merge anyway)
          Jarek
          • 2. Re: Merge table cells based on paragraph style
            graemem34292562 Level 1
            Hello - your solution worked a treat!
            One enhancement would once completed rename merged "tableBodyMerge" rows to "TableBody"
