4 Replies Latest reply on Dec 7, 2015 6:14 PM by djeasyb2006
    EXPORTING WITH ADOBE PREMIERE ELEMENTS 12
    djeasyb2006 Level 1
      Hello, I am using Adobe Premiere Elements 12.  I have been having issues with the export covering the entire screen after export.  I have been using these settings:
      H.264
      AVCHD
      MP4   1920 x 1080p
      NTSC
      25 fps
      Widescreen 16:9
      After exporting there is black space on both sides of the film.   Are there other settings that I am missing in preferences that's causing this to happen that I don't have
      knowledge of?
      Please Help... Thanks
        • 1. Re: EXPORTING WITH ADOBE PREMIERE ELEMENTS 12
          A.T. Romano Level 7
          djeasyb
          What are the properties of what you are importing to the project's Timeline, and what project preset have you (manually) or the project (automatically) set as the project preset.
          If you do not know the video properties, please tell us the brand/model/setting of the camera that recorded the video. That usually gives us that video properties information for troubleshooting purposes.
          Please tell us what the readings are for Editing Mode, Timebase, Frame Size, and Pixel Aspect Ratio (even if the fields look grayed out) under Edit Menu/Project Settings/General. That will tell us what project settings were set.
          Let us start here and use the above information to plan troubleshooting strategy.
          Thank you.
          ATR
          • 2. Re: EXPORTING WITH ADOBE PREMIERE ELEMENTS 12
            djeasyb2006 Level 1
            Thanks for your reply.   I look at the project settings it says:
            DSLR
            25 FRS.
            1920 1080
            Pixel Aspect Ratio: (1.0)
            Title safe area: 20%horizontal  20%vertical
            Action safe area  10%  10%vertical
            PRESET:
            MPEG2
            1620 x 1080
            25 frs
            NTSC
            Audio: MPEG, 384 kbps, 48khz, 16 bit. stereo
            file size: 372.74mb
            • 3. Re: EXPORTING WITH ADOBE PREMIERE ELEMENTS 12
              A.T. Romano Level 7
              djeasyb
              Thanks for the follow up.
              Could you find out what the details are for what you are putting on the Timeline for export.
              Is it 1920 x 1080p25 or something else.
              There are several problem with your details. We need to sort through the details.
              NTSC characteristically uses a frame rate of 29.97/30 or 59.94 frames per second.
              It is PAL that characteristically uses a frame rate of 25 or 50 frames per second.
              So it is not understood how 25 fps and NTSC got into that one description.
              MPEG2
              1620 x 1080
              25 frs
              NTSC
              file size: 372.74mb
              Important: the first step is to find out what you are putting on the Timeline for export - is it 1920 x 1080p25 or something else. And is the "1620 x 1080" a misprint. Did you mean to type "1920 x 1080"?
              If your project preset that you gave (that DSLR setting) is correct and you want to export your Timeline content as MPEG2, then
              Publish+Share
              Computer
              MPEG
              with Presets = HDTV 1080p25 High Quality.
              But, all starts with a description of what you are putting on the Timeline for export.
              Please consider. Any questions or need clarification on any of the above, please do not hesitate to ask.
              ATR
              • 4. Re: EXPORTING WITH ADOBE PREMIERE ELEMENTS 12
                djeasyb2006 Level 1
                Thank you... I will do some test exports and contact you tomorrow.
