1 Reply Latest reply on Feb 12, 2009 3:59 PM by akki_sagar
    PLEASE HELP!! Need some way to read header text in advanced datagrid using QTP
    akki_sagar Level 1
      I am writing a function to read column names in advanced data grid. There is no operation for that and any of the properties that I can use to read the column names.
      Please suggest any way that I can get the names of columns in the advanced data grid.
        • 1. PLEASE HELP!! Need some way to read header text in advanced datagrid using QTP
          akki_sagar Level 1
          I hope to hear something from adobe folks...I am providing more info.....
          I am using QTP 9.2 and Flex 3 add-in available from Adobe.
          My application has flex Advanced datagrid object and I am trying to read column names for the datagrid.
          I have contacted developers and they told me that column names for flex advanced datagrid are stored in "Header Text"
          I have tried reading "Header Text" using GetROProperty("HeaderText") but it doesn't return anything.
          I have tried the following code:
          x = Browser("app").FlexApplication("flexapp").FlexCanvas("Canvas").FlexAdvancedDatagrid("esti mategridid").GetROProperty("Header Text")
          msgbox x
          I have also tried getting value for column names using other available properties for webtables like outerhtml, outertext, alt etc. but I don't get any data.
          Part of the problem may be because none of the above mentioned properties are supported by Flex Advanced datagrid.
          I have also tried getting child objects but I always get the data in datagrid as values but not the column names.
          My primary reason for getting column names is to write a function to update cell in datagrid independent of application. So, I want to pass column name as a parameter to the function and get the corresponding columnIndex in the function by comparing the parameter value against column names.
          Thanks to all for you help...
