Craig,
I had not made any changes to styles for quite a while (month
or more). When this event occurred, I made several attempts to edit
the topic in the latest work completed before compiling. But each
compile resulted in the same event.
I selected all topics in accordance to the RoboHelp Help,
then Properties Appearances tab. I checked all the bold items and
they were still as original. That is, the Drop-down hotspot and
Expanding hotspot all the same; Hyperlink + color: Green, cursor:
hand; fint-style: italic; x-text-underline: off; x-text-overline:
off; x-text-line-through: off; font-size: 10pt.
Expanding text; SPAN + font-style: italic; font-weight:
normal: color: Teal; font-size: 10pt; x-text-underline: Off;
As a matter of fact I can select the style sheet
(HtmlHelp.css) and make some edits, but the Apply button does not
enable. When I made the last edit prior to my original email, I did
check the original stype sheet. I had two listed in the projects
tab: default.css and HtmlHelp.css. I checked the edits in the
Appearance tab and I do not remember if the Apply button was
active, but I assume that it was since I now only have the
HtmlHelp.css listed in the project tab Syple Sheets folder.
I still get the expanded and drop downs appearing in the
color Blue and underlined just as the Hyperlink.
Any suggestions????
Thanks, Bruce
