Succeeding CFSELECT not binding correctly
kodemonki Feb 11, 2009 9:56 AMI've searched the web, and a number of awesome tutorials, but
I keep getting stuck on my bind failing, but I can't figure out
why! I am using the name of the preceeding cfselect for the current
method argument, I've checked that both cfselects work correctly
when the second does not depend on the first. It looks like the
binding happens AFTER the error, which I'm not sure how to fix. And
it also looks like it's binding to all the data returned from the
first cfselect call, instead of just the default selected id. If
anyone can show me the error of my ways, I'd very much appreciate
it!
[code]
.cfm
<cfselect name="type_id" bind="cfc:calls.call_types()" bindOnLoad="true" />
<cfselect name="concern_id" bind="cfc:calls.get_concerns({type_id})" />
calls.cfc
<cfcomponent>
<cfset dsn = 'admi-prod'>
<!--- get types of calls --->
<cffunction name="call_types" access="remote" returntype="array">
<cfset var result = arrayNew(2)>
<cfset var data = querynew("concern_type, type_id")>
<cfcontent type="text/html" reset="yes">
<cfset queryAddRow(data)>
<cfset querySetCell(data,"concern_type", "Special Projects")>
<cfset querySetCell(data, "type_id", 16)>
<cfset querySetCell(data,"concern_type", "QA")>
<cfset querySetCell(data, "type_id", 36)>
<cfquery name="data2" dbtype="query">
SELECT concern_type, type_id
FROM data
</cfquery>
<cfloop index="i" from="1" to="#data2.RecordCount#">
<cfset result [1] = data2.type_id>
<cfset result [2] = data2.concern_type>
</cfloop>
<cfreturn result>
</cffunction>
<cffunction name="get_concerns" access="remote" returntype="array">
<cfargument name="type_id" type="numeric" required="yes">
<cfset var data = "">
<cfset var i = 0>
<cfquery name="data" datasource="#dsn#">
SELECT concern, concern_id
FROM pbr_concerns_masters
WHERE concern_type = #arguments.type_id#
ORDER BY concern
</cfquery>
<cfloop index="i" from="1" to="#data.RecordCount#">
<cfset result [1] = data.concern_id>
<cfset result [2] = data.concern>
</cfloop>
<cfreturn result>
</cffunction>
</cfcomponent>
cfdebug:
info:bind: Assigned bind value: '16,Special Projects,36,QA' to type_id.value
info:http: CFC invocation response: [[16,"Special Projects"],[36,"QA"]]
error:bind: Bind failed, element not found: type_id
[/code]
[code]
.cfm
calls.cfc
<cfcomponent>
FROM data
</cfquery>
</cfloop>
<cfreturn result>
</cffunction>
<cfset var i = 0>
ORDER BY concern
</cfquery>
</cfloop>
<cfreturn result>
</cffunction>
</cfcomponent>
cfdebug:
[/code]
