2 Replies Latest reply on Feb 9, 2009 1:23 PM by ricekingusa
    Gallery trouble
      I have made an XML Gallery in Flash but there is a problem, it works very well however some of the photos are portrait and this causes a problem as gaps are created between photos.
      any ideas?
      link to files: http://www.actionscript.org/forums/attachment.php3?attachmentid=31258&d=1234123242
        • 1. Re: Gallery trouble
          What do you mean when you say gaps are created between them? Do you mean you have the same acreage defined for each image such that there are wider spaces between images when portrait layouts get planted in the mix? If so, you should be able to plant them and designate their spacing dynamically instead of using a fixed allocation of space.
          • 2. Re: Gallery trouble
            ricekingusa Level 1
            It would be nice to help you but your swf has a password field to go further in your app. Mind sharing the secret to understand your "gaps"
