1 Reply Latest reply on May 10, 2006 9:52 AM by Newsgroup_User
    _level0.<instance name>
    LISTi
      I have created a dynamic text instance whose name is feedback_txt and attached to it a global text variable called feedback.
      However, on stage it displays _level0.feedback instead of the value of the global variable feedback.
      What am I doing wrong?
        • 1. Re: _level0.<instance name>
          Level 7
          LISTi,
          > called feedback.
          Not sure what you mean by "attached it to a global text variable" -- do
          you mean the Var field of the Property inspector?
          What displays this? The text field itself?
          Not sure yet. I'm not sure what you mean by global variable.
          There's a special _global object in ActionScript ... did you make your text
          a property of that object? Let's see your code.
          David
          stiller (at) quip (dot) net
          Dev essays: http://www.quip.net/blog/
          "Luck is the residue of good design."
