11 Replies Latest reply on Dec 15, 2015 2:38 AM by Test Screen Name
    exportAsFDF method fails to export Comments made unless a document is Reader Extended
    michaelw51771899 Level 1
      Problem-Description:
      Adobe Reader 11 JavaScript exportAsFDF method fails to export Comments made unless a document is Reader Extended
      Method:
      1. Open a document that has NOT been Reader Extended
      2. Add comments to the PDF file
      3. Use the following JavaScript to export comments
      // Import permission
      statImport = PDDocPermRequest(pdDoc,PDPermReqObjAnnot,PDPermReqOprImport,NULL);
      sprintf(szMsg,"canLoadMarkup() AnnotPerm(import)= %d.\n",statImport);
      traceMsg(szMsg);
      // Export permission
      statExport = PDDocPermRequest(pdDoc,PDPermReqObjAnnot,PDPermReqOprExport,NULL);
      sprintf(szMsg,"canLoadMarkup() AnnotPerm(export)= %d.\n",statExport);
      if (statImport == 0 && statExport == 0)
      // see ShowPermissions.cpp from Adobe Plugin SDK sample.
      // statImport = -1 - permission denial
      // statImport = 0 - permission granted
      // statImport >= 1 - permission either unknown or pending
      sprintf(szMsg,"##### reader and permissions granted: %s", prodName);
      traceMsg(szMsg);
      retFlag = TRUE;
      else
      sprintf(szMsg,"%s: Reader implies NOT okay to load markup", prodName);
      traceMsg(szMsg);
      retFlag = FALSE; // Reader can not load markup.
      Result:
      No comments are exported
      Expected:
      That if the file allows commenting via checking the PDDocPermRequest then it should also allow exporting comments.
