6 Replies Latest reply on Feb 11, 2009 2:39 PM by Newsgroup_User
    Collection Event event.items.length Does Not Match the No. of Items
    alice_data
      I have been digging around the problem of how to get my CollectionEvent to work, and I seem to be able to see the problem, but I am not sure how to get it to work properly.
      In my example, it works when I try to check or uncheck the check boxes as long as it is the top 2 items of the list, but after that. It never gives me the correct input. I can check the boxes, but the message is never updated accurately.
      Can anyone please help me out?
      Thanks in advance.
      Alice
        • 1. Re: Collection Event event.items.length Does Not Match the No. of Items
          rtalton Level 4
          Have you tried using selectedItems.length? Like:
          trace_txt.text = myDG.selectedItems.length.toString();
          • 2. Re: Collection Event event.items.length Does Not Match the No. of Items
            Level 7
            "alice_data" <webforumsuser@macromedia.com> wrote in message
            news:gmsbjo$ahc$1@forums.macromedia.com...
            > Hi,
            > to
            > get it
            > to work properly.
            > In my actionscript, it seems to only tell that event.items.length is 1,
            > while I am calling my array collection from the HTTPService, and I have
            > tested
            > the length of my Array Collection, which seems to be accurate. What I
            > tried to
            > do is to use that number in the CollectionEvent function, but that does
            > not
            > work at all.
            > Thanks in advance.
            If only one item changed, I'd expect event.items.length to be 1...?
            • 3. Re: Collection Event event.items.length Does Not Match the No. of Items
              alice_data Level 1
              Thanks for Amy's point. I think the question is here how to make it so that every single checkbox can detect which is checked and which is not. Right now, when I check 10 of them, but if I leave any of the first 3 elements unchecked, my total checked result returns 0, but if I check one of the first 3, it brings back the correct number.
              I thought I am using a for loop here, but every time when I try to get getItemAt(i).selected printed out correctly, it always returns me a 0. How come the selected variable changes only when I check on the first 2 check boxes of the array?
              Thanks in advance.
              Alice
              • 4. Re: Collection Event event.items.length Does Not Match the No. of Items
                Level 7
                news:gmul4e$7eb$1@forums.macromedia.com...
                > Hi,
                > that
                > now,
                > unchecked,
                > brings
                > come
                > of
                > the array?
                Could you be a bit more clear on what you're doing here? Do you have check
                boxes repeated with a repeater, or a DataGrid with check boxes as one of the
                itemRenderers? Something else?
                • 5. Collection Event event.items.length Does Not Match the No. of Items
                  alice_data Level 1
                  Hi, Amy:
                  Yes, like you guessed, the code I have provided at the original post is a DataGrid with check boxes as one of the itemRenderers. The checkboxes are checkable, but it seems that it does not change to true when I check them.
                  The only time they work is when I have the ones that are indexed smaller than 1. I hope I am making sense here.
                  Thanks again for your help.
                  • 6. Re: Collection Event event.items.length Does Not Match the No. of Items
                    Level 7
                    news:gmveo9$7qh$1@forums.macromedia.com...
                    > Hi, Amy:
                    > a
                    Here is some working code you can look at:
                    http://www.returnundefined.com/2007/11/efficient-reusable-and-centered-checkbox-renderers- for-datagrids
