9 Replies Latest reply on Dec 15, 2015 5:16 AM by oliverIntergrafika
    Is there a way to get the current timeline frame number in Frame Animation mode?
    oliverIntergrafika Level 2
      I would like to know which frame is the active frame in Frame Animation mode.
      I am using three scriptListener funcitons in order to avoid frame 1 propagation to ruin the timeline when something is changing in frame 1:
      duplicateTimelineFrame(); <<< do something with layers >>>; deleteTimelineFrame(); stepBackOneTimelineFrame();
      But when im doing something on the last frame, this sequence is stepping back one more frame.
      I have found a few user made getCurrentFrame(), getFrameCount() functions but they all working on Video Timeline, and returnning 0 when I am trying to use them on a Frame Animation.
      The PS DOM dont have any timeline related calsses or methods and I am confused from the script listener output. I dont have the willpower and intelligence to reverse engineer the code and make modifications in it.
      Thank You!
        • 1. Re: Is there a way to get the current timeline frame number in Frame Animation mode?
          te_co Level 3
          i too have this question. I could only figure out how to set selection to a frame. But not how to retrieve current selection
          • 2. Re: Is there a way to get the current timeline frame number in Frame Animation mode?
            c.pfaffenbichler Level 9
            If a direct determination should be impossible a work-around presents itself:
            • set the animationFrameDelay of the selected Frame/s to some outlandish number
            • check all the Frames for that number thus identifying the affected Frames
            • undo the changing of the animationFrameDelay
            Now the second part may not be as straightforward as would be desirable as I am unsure one can determine the total number of Frames beforehand, but either deleting the first frame within a try clause until it throws an error or marking first and last Frame with another outlandish animationFrameDelay would be options.
            • 3. Re: Is there a way to get the current timeline frame number in Frame Animation mode?
              Hi c.pfaffenbichler!
              Thanks for your answer! How do you know these actionDescriptor and actionReference solutions? I am trying to understand them since weeks, searching for script examples, making modifications to them without success. I am unable to find a tutorial, or figure, or diagram about their structure.
              Is there a .jsx library which is handlig these cryptic statements and constants? Did someone code the the missig DOM classes?
              I feel myself an idiot, because all the wasted time and effort trying to solve these basic problems.
              The sciptListener plugin exported the code below:
              function setFrameDelay( delay )
              var idsetd = charIDToTypeID( "setd" );
                  var desc5 = new ActionDescriptor();
                  var idnull = charIDToTypeID( "null" );
                      var ref2 = new ActionReference();
                      var idanimationFrameClass = stringIDToTypeID( "animationFrameClass" );
                      var idOrdn = charIDToTypeID( "Ordn" );
                      var idTrgt = charIDToTypeID( "Trgt" );
                      ref2.putEnumerated( idanimationFrameClass, idOrdn, idTrgt );
                  desc5.putReference( idnull, ref2 );
                  var idT = charIDToTypeID( "T  " );
                      var desc6 = new ActionDescriptor();
                      var idanimationFrameDelay = stringIDToTypeID( "animationFrameDelay" );
                      desc6.putDouble( idanimationFrameDelay, delay );
                  desc5.putObject( idT, idanimationFrameClass, desc6 );
              executeAction( idsetd, desc5, DialogModes.NO );
              Could you please instruct me, how to turn this into a getter function?
              Thanks a lot!
              Oliver
              • 4. Re: Is there a way to get the current timeline frame number in Frame Animation mode?
                Actually my own grasp on AM code is tenuous …
                But in this example I can provide the code:
                ////// get framedelay //////
                function getFrameDelay (theIndex) {
                var ref = new ActionReference();
                ref.putProperty(charIDToTypeID('Prpr'), stringIDToTypeID('animationFrameDelay'));
                ref.putIndex(stringIDToTypeID('animationFrameClass'), theIndex);
                //ref.putEnumerated(stringIDToTypeID('animationFrameClass'), charIDToTypeID( "Ordn" ), charIDToTypeID( "Trgt" ));
                var desc=new ActionDescriptor();
                desc.putReference(charIDToTypeID('null'), ref);
                var aaa = executeAction(charIDToTypeID('getd'), desc, DialogModes.NO);
                //checkDesc2 (aaa);
                return aaa.getDouble(stringIDToTypeID('animationFrameDelay'))
                • 5. Re: Is there a way to get the current timeline frame number in Frame Animation mode?
                  c.pfaffenbichler You are great! I owe You.
                  This is working. Ill put the 2 functions side by side and try to compare them. This will be my rosetta stone.
                  • 6. Re: Is there a way to get the current timeline frame number in Frame Animation mode?
                    I use this code when I need to figure out how to get at certain parameters of Photoshop, a Document or a Layer for example.
                    Maybe it can be helpful for you as well.
                    #target photoshop
                    //if (app.documents.length > 0) {
                    // application;
                    //ref.putEnumerated( charIDToTypeID("capp"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
                    // document;
                    ref.putEnumerated( charIDToTypeID("Dcmn"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
                    // layer;
                    //ref.putEnumerated( charIDToTypeID("Lyr "), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
                    var docDesc = executeActionGet(ref);
                    checkDesc2(docDesc);
                    ////// based on code by michael l hale //////
                    function checkDesc2 (theDesc) {
                    var c = theDesc.count;
                    var str = '';
                    for(var i=0;i<c;i++){ //enumerate descriptor's keys
                      str = str + 'Key '+i+' = '+typeIDToStringID(theDesc.getKey(i))+': '+theDesc.getType(theDesc.getKey(i))+'\n'+getValues (theDesc, i)+'\n';
                    alert("desc\n\n"+str);
                    ////// check //////
                    function getValues (theDesc, theNumber) {
                    switch (theDesc.getType(theDesc.getKey(theNumber))) {
                    case DescValueType.BOOLEANTYPE:
                    return theDesc.getBoolean(theDesc.getKey(theNumber));
                    break;
                    case DescValueType.CLASSTYPE:
                    return theDesc.getClass(theDesc.getKey(theNumber));
                    break;
                    case DescValueType.DOUBLETYPE:
                    return theDesc.getDouble(theDesc.getKey(theNumber));
                    break;
                    case DescValueType.ENUMERATEDTYPE:
                    return (typeIDToStringID(theDesc.getEnumerationValue(theDesc.getKey(theNumber)))+"_"+typeIDToStr ingID(theDesc.getEnumerationType(theDesc.getKey(theNumber))));
                    break;
                    case DescValueType.INTEGERTYPE:
                    return theDesc.getInteger(theDesc.getKey(theNumber));
                    break;
                    case DescValueType.LISTTYPE:
                    return theDesc.getList(theDesc.getKey(theNumber));
                    break;
                    case DescValueType.OBJECTTYPE:
                    return (theDesc.getObjectValue(theDesc.getKey(theNumber))+"_"+typeIDToStringID(theDesc.getObject Type(theDesc.getKey(theNumber))));
                    break;
                    case DescValueType.REFERENCETYPE:
                    return theDesc.getReference(theDesc.getKey(theNumber));
                    break;
                    case DescValueType.STRINGTYPE:
                    return theDesc.getString(theDesc.getKey(theNumber));
                    break;
                    case DescValueType.UNITDOUBLE:
                    return (theDesc.getUnitDoubleValue(theDesc.getKey(theNumber))+"_"+typeIDToStringID(theDesc.getUn itDoubleType(theDesc.getKey(theNumber))));
                    break;
                    default:
                    break;
                    • 7. Re: Is there a way to get the current timeline frame number in Frame Animation mode?
                      It seems very useful like a swiss knife! I hardly wait to try it out on various descriptors. I really appreciated for Your help!
                      • 8. Re: Is there a way to get the current timeline frame number in Frame Animation mode?
                        I’m just trying to "pass on" some of the help I got from (at the time) Forum regulars like xbytor, Mike Hale, Paul Riggott and others.
                        • 9. Re: Is there a way to get the current timeline frame number in Frame Animation mode?
                          //////////////// TIMELINE
                          try{
                          #target "Photoshop" ;
                          Timeline = {
                            selectFrame: function( theIndex )
                            try
                            var idslct = charIDToTypeID( "slct" );
                            var desc152 = new ActionDescriptor();
                            var ref84 = new ActionReference();
                            ref84.putIndex( idanimationFrameClass, theIndex );
                            desc152.putReference( idnull, ref84 );
                            executeAction( idslct, desc152, DialogModes.NO );
                            catch ( e ) {
                            return false;
                            return theIndex;
                            getFrameCount: function () // till no faster way to retrieve it
                            this.markFrame();
                            var f = 1;
                            while( this.selectFrame( f++ ) )
                            this.selectMarkedFrame();
                            this.unMarkFrame();
                            return f-2;
                            selectMarkedFrame: function () {
                            var f = 1;
                            while( this.selectFrame( f++ ) && !this.isMarked() )
                            markFrame: function ()
                            this.setFrameDelay ( this.getFrameDelay() + 1000 );
                            unMarkFrame: function ()
                            this.setFrameDelay ( this.getFrameDelay() - 1000 );
                            isMarked: function ()
                            return this.getFrameDelay() >= 1000;
                            setFrameDelay: function ( delay )
                               var desc = new ActionDescriptor();
                               desc.putReference( charIDToTypeID( "null" ), ref );
                               desc6.putDouble( stringIDToTypeID( "animationFrameDelay" ), delay );
                               desc.putObject( idT, stringIDToTypeID( "animationFrameClass" ), desc6 );
                            executeAction( idsetd, desc, DialogModes.NO );
                            getFrameDelay: function ( theIndex )
                            if ( theIndex ) {
                            else {
                               // this.checkDesc2 (aaa);
                            duplicateFrame: function()
                            executeAction( stringIDToTypeID( "makeFrameAnimation" ), undefined, DialogModes.NO ); // crate timeline
                               ref.putEnumerated( stringIDToTypeID( "animationFrameClass" ), charIDToTypeID( "Ordn" ), charIDToTypeID( "Trgt" ) );
                               executeAction( charIDToTypeID( "Dplc" ), desc, DialogModes.NO );
                            deleteFrame: function()
                               try
                                   executeAction( charIDToTypeID( "Dlt " ), desc, DialogModes.NO );
                               } catch ( e )
                                   $.writeln("No Timeline, Cannot delete!")
                            stepBackOneFrame: function()
                            var idanimationFrameActivate = stringIDToTypeID( "animationFrameActivate" );
                               var desc9 = new ActionDescriptor();
                                   var ref4 = new ActionReference();
                                   var idPrvs = charIDToTypeID( "Prvs" );
                                   ref4.putEnumerated( idanimationFrameClass, idOrdn, idPrvs );
                               desc9.putReference( idnull, ref4 );
                            executeAction( idanimationFrameActivate, desc9, DialogModes.NO );
                            checkDesc2: function  ( theDesc ) {
                               var str = '';
                               for( var i=0; i<c; i++ ){ //enumerate descriptor's keys
                                   str = str + 'Key '+ i + ' = ' + typeIDToStringID(theDesc.getKey(i)) + ': ' + theDesc.getType(theDesc.getKey(i))+'\n'+ this.getValues (theDesc, i)+'\n';
                            ////// check //////
                            getValues: function  ( theDesc, theNumber ) {
                               break;
                               break;
                               break;
                               return (typeIDToStringID(theDesc.getEnumerationValue(theDesc.getKey(theNumber)))+"_"+typeIDToStringID(theDesc.getEnumerationType(theDesc.getKey(theNumber))));
                               break;
                               break;
                               break;
                               return (theDesc.getObjectValue(theDesc.getKey(theNumber))+"_"+typeIDToStringID(theDesc.getObjectType(theDesc.getKey(theNumber))));
                               break;
                               break;
                               break;
                               return (theDesc.getUnitDoubleValue(theDesc.getKey(theNumber))+"_"+typeIDToStringID(theDesc.getUnitDoubleType(theDesc.getKey(theNumber))));
                               break;
                               default:
                               break;
                          } catch ( e ) { alert ( e ) };
                          This is a short timeline manipulation .jsx. Now I can continue working on my little project.
