4 Replies Latest reply on Dec 13, 2015 5:21 AM by Евгений Гонжа
    Problem dragging library CC items
    Евгений Гонжа Level 1
      first of all - sorry for my English - Google :-)
      I have a problem with a new cloud-based library.
      This problem only with InDesign
      I can not drag and drop objects from the library to the InDesign document
      The program displays a message that "You do not have sufficient rights or object does not exist, or the object is occupied by another program"
      I have tried to change the permissions in the Security tab (folder properties in windose) - did not help
      I found a solution to this:
      1 - run InDesign
      2 - open a new document
      3 - drag and drop objects from the library CC
      4 - I read the error message: - ((((
      5 - I swear :-)
      6 - close InDesign
      7 - repeat p.1-3
      7a - if this does not work, then I open Illustrator and drag and drop object from the library into Illustrator. And then I repeat p.1-3
      What is the problem - I do not know
      If you have a similar problem - try my recipe
      If you will - I will be happy.
      Success!
