12 Replies Latest reply on Feb 11, 2009 8:56 AM by Ned Murphy
    variable for counting items clicked
    W_Bell Level 1
      I am not sure about ther variable method I am trying to make.
      It is supposed to keep track of how many buttons are pressed out of 6 buttons.
      My code is:
      //Set the variable
      var onoff =0;
      //press button to add or subtract from the var
      myButton.onPress = function() {
      onoff = 0+1;
      if (onoff=6) {//All on/off memory var
      menuButton_All_On._visible = false;
      } else {
      menuButton_All_On._visible = true;
      //Problem is I think myButton press is setting the var to 0 each time it adds or subtracts from it.
        • 1. variable for counting items clicked
          It probably equals 1 after each click since you assign it to be so. Try:
          onoff += 1;
          I don't see where anything is subtracting though.
          • 2. Re: variable for counting items clicked
            W_Bell Level 1
            I guess te code should be more complete.
            Here it is with your syntax.
            Is this what you mean?
            //Set the variable
            var onoff =0;
            //press button to "add" to the var
            onoff +=1;
            } else {
            //press button to "subtrat" to the var
            myButton_2.onPress = function() {
            onoff -=1;
            } else {
            //This seems to be a lot of code to do the 2 functions...
            can anyone suggest a more streamlined way?
            Thank you NedWebs
            • 3. Re: variable for counting items clicked
              rlc5611 Level 1
              use == with if
              • 4. Re: variable for counting items clicked
                Your code is not going to give you the result first described... "It is supposed to keep track of how many buttons are pressed out of 6 buttons." So you may have to re-explain the true goal of this code, along with what's going on with the "menuButton_All_On._visible" element.
                And as ric mentions, use == for comparisons
                • 5. variable for counting items clicked
                  W_Bell Level 1
                  That was a poor start for this thread, sorry.
                  Here is more comprehensive code that I think may work more efficiently.
                  The problem may be that the "var" can go past 6 or less than 0
                  I think this won't apply though it there can only be 6 buttons that can execute the + and 6 for the -.
                  Please see attached code:
                  • 6. Re: variable for counting items clicked
                    My questions still stand. What are you really trying to accomplish, and what goes on with that MenuButton_All_On element.
                    Even if there are 6 buttons, you could press the same Up button 6 times and the show is over (?), so it's not clear what the scenario involves,
                    • 7. variable for counting items clicked
                      W_Bell Level 1
                      the 6 up buttons turn themselves ._visible = false so they won't be seen once clicked. So there can only be 6 clicks total.
                      When these upButtons are clicked the down state button appears from underneath them. These down state buttons then executes the - code and turn on the up buttons. So again there can only be 6 clicks one way or another.
                      The "MenuButton_All_On" is a master button to turn all stuff {including the button states) on or off.
                      That is why I needed some way to show this button off after all the single items are off or on.
                      It is not to important if only 4 or 5 is selected because it would still turn the reast on or off.
                      The problem I see now here is that, when the buttons are all off and the user clicks on of the down state
                      buttons, it turns the "MenuButton_All_On" back on only after one click. This has to happen now after 6 "-" clicks.
                      • 8. Re: variable for counting items clicked
                        So you can click the same Up button 6 times and get them all to disappear? Is that what you want?
                        • 9. variable for counting items clicked
                          W_Bell Level 1
                          Yes,
                          The problem I see now here is that, when the buttons are all off and the user clicks on the down state buttons, it turns the "MenuButton_All_On" back on only after one click. This has to happen now again only after 6 "-" clicks.
                          • 10. Re: variable for counting items clicked
                            You need to have some stored info regarding the clicks and who's currently playing. You could have a boolean variable, call it upMode or something and set it to true when the Up buttons are active. When you reach that 6 count, switch that variable value to false until the Down folks do their job.
                            Or, you could try just adding a second conditional instead of the "else" by itself, have it...
                            else if(onoff == 0){
                            That may take care of the counting down side of things. It should work if you are only counting up to start with
                            • 11. Re: variable for counting items clicked
                              W_Bell Level 1
                              This code will address the task.
                              Thank you NedWebs
                              • 12. Re: variable for counting items clicked
                                You're welcome
