2 Replies Latest reply on Feb 9, 2009 9:29 AM by ntsiii
    HTTPService Problem with IIS
    RayGerena
      I've written a simple flex app that populates a tree control from a .XML.
      It works fine locally. It works fine when I upload the files to an Apache server. However when I test it on IIS on Windows XP Server (which, of course where I need it to actually work most) it fails with the following error:
      quote:
      RPC Fault faultString="HTTP request error" faultCode="Server.Error.Request" faultDetail="Error: [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032: Stream Error. URL: http://localhost/client/flexportal/bin-debug/XML/Reporttree.xml" URL: XML/Reporttree.xml
      at mx.rpc::AbstractInvoker/ http://www.adobe.com/2006/flex/mx/internal::faultHandler()[C:\autobuild\3.2.0\frameworks\p rojects\rpc\src\mx\rpc\AbstractInvoker.as:220
      at mx.rpc::Responder/fault()[C:\autobuild\3.2.0\frameworks\projects\rpc\src\mx\rpc\Responder .as:53]
      at mx.rpc::AsyncRequest/fault()[C:\autobuild\3.2.0\frameworks\projects\rpc\src\mx\rpc\AsyncR equest.as:103]
      at DirectHTTPMessageResponder/errorHandler()[C:\autobuild\3.2.0\frameworks\projects\rpc\src\ mx\messaging\channels\DirectHTTPChannel.as:362]
      at flash.events::EventDispatcher/dispatchEventFunction()
      at flash.events::EventDispatcher/dispatchEvent()
      at flash.net::URLLoader/onComplete()
      The MXML code is pretty simple and has been attached.
      Is there some kind of setting that needs to be set up on IIS to make this work?
      Any help would be greatly appreciated.
