4 Replies Latest reply on Dec 16, 2015 9:56 AM by aguman
    Photoshop script to export groups as folders?
    aguman
      Hello,
      I am working with a .psb file that has around 100 groups with layers in them. I would like to export those groups into actual folders containing a .png file for each individual layer inside. If I had to create the folders manually and re-organise the png files inside them it would take me several hours. I can't seem to find a script that works. Any ideas? Thank you very much in advance.
        • 1. Re: Photoshop script to export groups as folders?
          c.pfaffenbichler Level 9
          How frequent is the task for you?
          • 2. Re: Photoshop script to export groups as folders?
            aguman Level 1
            Thank you for your answer. I work a lot on animations with scanned drawings, so very frequent.
            • 3. Re: Photoshop script to export groups as folders?
              SuperMerlin Level 5
              This script will create a folder of the filename and folders of the groupnames with pngs.
              #target photoshop;
              app.bringToFront();
              main();
              function main(){
              if(!documents.length) return;
              try{
              var doc = app.activeDocument;
              app.displayDialogs = DialogModes.NO;
              pngSaveOptions = new PNGSaveOptions();
              var LSets = getLayerSets();
              if(LSets.length < 1) return;
              try{
              var Name = doc.name.replace(/\.[^\.]+$/, '');
              var docPath = doc.path;
              }catch(err){
                  alert("This document needs to be saved before running this script!");
                  return;
              var OutputPath = Folder(docPath + "/" + Name);
              if(!OutputPath.exists) OutputPath.create();
              for(var f in LSets){
                  var LayerSetIndexs = getChildIndex(Number(LSets[f][0]),false);
                  var groupFolder = Folder(OutputPath + "/" + LSets[f][1].toString());
                  if(!groupFolder.exists) groupFolder.create();
                  for(var x in LayerSetIndexs){
                     selectLayerByIndex(Number(LayerSetIndexs[x]));
                     var Kind = activeDocument.activeLayer.kind;
                      var Shape = isShapeLayer();
              if(Kind ==LayerKind.NORMAL || Kind == LayerKind.SMARTOBJECT || Kind == LayerKind.TEXT || Shape == true){
                  dupLayers();
                  var saveFile = File(groupFolder + "/" +  activeDocument.activeLayer.name + ".png");
                    activeDocument.saveAs(saveFile, pngSaveOptions, true, Extension.LOWERCASE);
                  app.activeDocument.close(SaveOptions.DONOTSAVECHANGES);
                  }else{ continue; }
              }catch(e){}
              function isShapeLayer(){
              var ref = new ActionReference();
              ref.putEnumerated( charIDToTypeID('Lyr '),charIDToTypeID('Ordn'),charIDToTypeID('Trgt') );
              desc =  executeActionGet(ref);
              if(!desc.hasKey(stringIDToTypeID('adjustment')) ) return false;
              if(desc.getBoolean(stringIDToTypeID('hasVectorMask' )) == true)  return true;
              return false;
              function getLayerLayerSectionByIndex( index ) {
                 ref.putIndex(charIDToTypeID('Lyr '), index);
                 return typeIDToStringID(executeActionGet(ref).getEnumerationValue(stringIDToTypeID('layerSection')));
              function getLayerNameByIndex( index ) {
                  ref.putIndex( charIDToTypeID( 'Lyr ' ), index );
                  return executeActionGet(ref).getString(charIDToTypeID( 'Nm  ' ));
              function skipNestedSets( layerIndex ){
                 var isEnd = false;
                 layerIndex = app.activeDocument.layers[app.activeDocument.layers.length-1].isBackgroundLayer ? layerIndex-2:layerIndex;
                 while(!isEnd){
                    layerIndex--;
                    if( getLayerLayerSectionByIndex( layerIndex ) == 'layerSectionStart' ) layerIndex = skipNestedSets( layerIndex );
                    isEnd = getLayerNameByIndex(layerIndex) == '</Layer group>' ? true:false;
                 return layerIndex-1;
              function getChildIndex(idx, skipNested ){
                 var layerSetIndex = idx;
                 var isEndOfSet = false;
                 var layerIndexArray = [];
                 while(!isEndOfSet){
                    layerSetIndex--;
                    if( getLayerLayerSectionByIndex( layerSetIndex ) == 'layerSectionStart' && skipNested ){
                       layerSetIndex = skipNestedSets( layerSetIndex );
                if(getLayerLayerSectionByIndex( layerSetIndex ) == undefined) break;
                    isEndOfSet = getLayerNameByIndex(layerSetIndex) == '</Layer group>' ? true:false;
                   if(!isEndOfSet ) layerIndexArray.push( layerSetIndex );
                 return layerIndexArray;
              function getLayerSets(){
                 ref.putProperty( charIDToTypeID( "Prpr" ), charIDToTypeID( 'NmbL' ));
                 ref.putEnumerated( charIDToTypeID('Dcmn'), charIDToTypeID('Ordn'), charIDToTypeID('Trgt') );
                 var count = executeActionGet(ref).getInteger(charIDToTypeID('NmbL')) +1;
                 var Names=[];
              try{
                  activeDocument.backgroundLayer;
              var i = 0; }catch(e){ var i = 1; };
                 for(i;i<count;i++){
                     if(i == 0) continue;
                      ref.putIndex( charIDToTypeID( 'Lyr ' ), i );
                      var desc = executeActionGet(ref);
                      var layerName = desc.getString(charIDToTypeID( 'Nm  ' ));
                      if(layerName.match(/^<\/Layer group/) ) continue;
                      var layerType = typeIDToStringID(desc.getEnumerationValue( stringIDToTypeID( 'layerSection' )));
                      var isLayerSet =( layerType == 'layerSectionContent') ? false:true;
                      if(isLayerSet) Names.push([[i],[layerName]]);
              return Names;
              function selectLayerByIndex(index){
              ref.putIndex(charIDToTypeID("Lyr "), index);
              var desc = new ActionDescriptor();
              desc.putReference(charIDToTypeID("null"), ref );
              desc.putBoolean( charIDToTypeID( "MkVs" ), true );
              try{
              executeAction(charIDToTypeID("slct"), desc, DialogModes.NO );
              }catch(e){}
              function dupLayers() {
              ref.putClass( charIDToTypeID('Dcmn') );
              desc.putReference( charIDToTypeID('null'), ref );
              desc.putString( charIDToTypeID('Nm  '), 'Temp' );
              var ref25 = new ActionReference();
              ref25.putEnumerated( charIDToTypeID('Lyr '), charIDToTypeID('Ordn'), charIDToTypeID('Trgt') );
              desc.putReference( charIDToTypeID('Usng'), ref25 );
              desc.putInteger( charIDToTypeID('Vrsn'), 5 );
              executeAction( charIDToTypeID('Mk  '), desc, DialogModes.NO );
              • 4. Re: Photoshop script to export groups as folders?
                aguman Level 1
                This worked like a charm. I could hug you right now, you saved me a lot of time. Thank you so much!
