5 Replies Latest reply on Dec 14, 2015 7:18 PM by bec2702
    Lightroom 6 constantly crashing on iMac & Macbook (GP unchecked)
    bec2702
      Hi there, I use Lightroom on both my PC and laptop. On my computer it seems to work ok but occasionally crashes here and there.
      I have already unchecked the graphics processor and it hasn't stopped the crashes, although the photos do seem to load a little faster. (Can I please just mention here, I never had an issue with v5, but v5 doesn't read the data from my newer camera).
      Anyway, Lightroom was working on my laptop good enough that I didn't want to throw it against a wall, however last week it started getting pretty buggy and would constantly crash on me, or wouldn't want to load any photos/slideshows, but after I force closed Lightroom and restarted my computer and it seemed to work fine until yesterday..
      I have been unable to load a single photo without Lightroom crashing and the slideshow refuses to load, instead the whole program freezes and requires a force close. I am also constantly being prompted to sign into Lightroom mobile.
      My computers have the latest Adobe updates and I am just installing El Captain onto the macbook now, although I don't see how it will effect how Lightroom runs..
      Has anyone else had this issue and what did you do to resolve it?
        • 1. Re: Lightroom 6 constantly crashing on iMac & Macbook (GP unchecked)
          Akash Sharma Adobe Employee
          Hi bec
          What devices(Externally:-Harddrive,Phone,Tablet ) do you have connected to your computer when you use Lightroom?
          Please share Help>>System info from Lightroom with us.
          Also post the crash report.
          Regards
          Akash
          • 2. Re: Lightroom 6 constantly crashing on iMac & Macbook (GP unchecked)
            bec2702 Level 1
            Here is the system info from my iMac. I will have to reply again from my macbook to give the system info for that one. I do not use any external devices with Lightroom so it seemed odd that it just began prompting me to log-in. I don't have any crash reports to share right now, but my laptop actually freezes (for hours on end) and generally leaves no crash report because I have to force close the program, but if it does I send the report to Adobe when prompted..
            Lightroom version: CC 2015.3 [ 1052427 ]
            License: Creative Cloud
            Operating system: Mac OS 10
            Version: 10.11 [2]
            Application architecture: x64
            Logical processor count: 4
            Processor speed: 3.1 GHz
            Built-in memory: 8,192.0 MB
            Real memory available to Lightroom: 8,192.0 MB
            Real memory used by Lightroom: 479.8 MB (5.8%)
            Virtual memory used by Lightroom: 861.3 MB
            Memory cache size: 46.7 MB
            Maximum thread count used by Camera Raw: 4
            Camera Raw SIMD optimization: SSE2,AVX,AVX2
            Displays: 1) 4096x2304
            Graphics Processor Info:
            Intel(R) Iris(TM) Pro Graphics 6200
            Check OpenGL support: Passed
            Vendor: Intel Inc.
            Version: 4.1 INTEL-10.12.13
            Renderer: Intel(R) Iris(TM) Pro Graphics 6200
            LanguageVersion: 4.10
            Application folder: /Applications/Adobe Lightroom
            Library Path: /Users/becpeterson/Pictures/Lightroom/Lightroom Catalog.lrcat
            Settings Folder: /Users/becpeterson/Library/Application Support/Adobe/Lightroom
            Installed Plugins:
            1) Aperture/iPhoto Importer Plug-in
            2) Canon Tether Plugin
            3) Facebook
            4) Flickr
            5) Leica Tether Plugin
            6) Nikon Tether Plugin
            Config.lua flags: None
            AudioDeviceIOBlockSize: 512
            AudioDeviceName: Built-in Output
            AudioDeviceNumberOfChannels: 2
            AudioDeviceSampleRate: 44100
            Build: Uninitialized
            CoreImage: true
            GL_ACCUM_ALPHA_BITS: 0
            GL_ACCUM_BLUE_BITS: 0
            GL_ACCUM_GREEN_BITS: 0
            GL_ACCUM_RED_BITS: 0
            GL_ALPHA_BITS: 8
            GL_BLUE_BITS: 8
            GL_DEPTH_BITS: 24
            GL_GREEN_BITS: 8
            GL_MAX_3D_TEXTURE_SIZE: 2048
            GL_MAX_TEXTURE_SIZE: 16384
            GL_MAX_TEXTURE_UNITS: 8
            GL_MAX_VIEWPORT_DIMS: 16384,16384
            GL_RED_BITS: 8
            GL_RENDERER: Intel(R) Iris(TM) Pro Graphics 6200
            GL_SHADING_LANGUAGE_VERSION: 1.20
            GL_STENCIL_BITS: 8
            GL_VENDOR: Intel Inc.
            GL_VERSION: 2.1 INTEL-10.12.13
            GL_EXTENSIONS: GL_ARB_color_buffer_float GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_seamless_cube_map GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_draw_buffers2 GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_rectangle GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array_bgra GL_APPLE_aux_depth_stencil GL_APPLE_client_storage GL_APPLE_element_array GL_APPLE_fence GL_APPLE_float_pixels GL_APPLE_flush_buffer_range GL_APPLE_flush_render GL_APPLE_object_purgeable GL_APPLE_packed_pixels GL_APPLE_pixel_buffer GL_APPLE_rgb_422 GL_APPLE_row_bytes GL_APPLE_specular_vector GL_APPLE_texture_range GL_APPLE_transform_hint GL_APPLE_vertex_array_object GL_APPLE_vertex_array_range GL_APPLE_vertex_point_size GL_APPLE_vertex_program_evaluators GL_APPLE_ycbcr_422 GL_ATI_separate_stencil GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_IBM_rasterpos_clip GL_NV_blend_square GL_NV_conditional_render GL_NV_depth_clamp GL_NV_fog_distance GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_barrier GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod
            • 3. Re: Lightroom 6 constantly crashing on iMac & Macbook (GP unchecked)
              bec2702 Level 1
              & here is the system info from my macbook.
              Version: 10.10 [5]
              Processor speed: 2.9 GHz
              Real memory used by Lightroom: 803.7 MB (9.8%)
              Virtual memory used by Lightroom: 1,728.8 MB
              Memory cache size: 819.9 MB
              Displays: 1) 1280x800
              Check OpenGL support: Failed
              Vendor: Intel Inc.
              Version: 4.1 INTEL-10.6.33
              Renderer: Intel HD Graphics 4000 OpenGL Engine
              Installed Plugins:
              3) Facebook
              4) Flickr
              Build: LR5x102
              CoreImage: true
              GL_ALPHA_BITS: 8
              GL_BLUE_BITS: 8
              GL_DEPTH_BITS: 24
              GL_GREEN_BITS: 8
              GL_RED_BITS: 8
              GL_RENDERER: Intel HD Graphics 4000 OpenGL Engine
              GL_STENCIL_BITS: 8
              GL_VERSION: 2.1 INTEL-10.6.33
              • 4. Re: Lightroom 6 constantly crashing on iMac & Macbook (GP unchecked)
                Thanks for the info
                On one computer(one with El captain installed)  you still  have GPU enabled under Lightroom>>Preferences>>Performance
                Try disabling it and check
                ~Akash
                • 5. Re: Lightroom 6 constantly crashing on iMac & Macbook (GP unchecked)
                  bec2702 Level 1
                  So odd because the box is unchecked when I check the preferences?? Also Lightroom on my macbook is inexplicably working again..?
                  I will restart my computer and see if the box becomes checked again, thank-you
