11 Replies Latest reply on Dec 16, 2015 8:17 AM by Liphou
    [JS] Variable text constructor
    Liphou Level 2
      Hello,
      I can not do it on replacing these two variables, the result is not good and there, I'm stuck.
      Thanks for your help
      Bonjour,
      je ne parviens pas à faire le remplacement sur ces deux variables, le résulta n'est pas bon et là, je suis bloqué.
      Merci pour votre aide
      var paragraph0 ="Chépitre 01.indd";
      var paragraph = app.activeDocument.name; //name file indesign is Chépitre 01.indd.
      alert(paragraph0.replace (/é/g, 'e') +'—' + paragraph.replace (/é/g, 'e'));
      result : "Chepitre 01.indd — Chépitre 01.indd" -> not good
        • 1. Re: [JS] Variable text constructor
          Luca Bisin
          I've tested the code you've posted and it works as you expect. Result is: Chepitre 01.indd—Chepitre 01.indd
          Maybe you'll need to add more details so we can reproduce your problem.
          • 2. Re: [JS] Variable text constructor
            Andreas Jansson Level 2
            I agree with Luca Bisin. I saved a document as "Chépitre 01.indd" and ran your script. This was the result:
            What version of InDesign do you have? This was CC 2015.2 (latest CC version).
            Perhaps there might be another ASCII / UTF8 representation of the letter "é" in the filename, than the letter é that we are testing with.
            Andreas
            • 3. Re: [JS] Variable text constructor
              Loic.Aigon Adobe Community Professional
              I second that.
              • 4. Re: [JS] Variable text constructor
                Liphou Level 2
                I work on mac (10.7.5) with InDesign CS6 (8.1), I just tested it on another machine, I have no problem (!!! ?????).
                Is it possible to reach saturation or other problem?
                I return on another machine tomorrow.
                thank you to all of you
                Je travail sur mac (10.7.5) avec indesign CS6 (8.1), je viens de tester sur une autre machine, je n'ai plus le problème (!!!?????).
                Est-il possible d'arriver à saturation ou autre problème ?
                Je retour sur l'autre machine demain.
                Merci à vous tous
                • 5. Re: [JS] Variable text constructor
                  Where do your document come from. Was it created and saved at your office ?
                  It looks like it was created on some other machine using a different encoding. Guessing that Chépitre would stand orginally for Châpitre. So the possible â to é translation would betray a change of encoding leading to characters mismatch.
                  One thing to try would be to do a idml loop to see if once reconstructed you would still face the issue.
                  FWIW
                  loic
                  • 6. Re: [JS] Variable text constructor
                    Hi Liphou,
                    I can see the same as you with InDesign CS6 v8.1.0 on Mac OSX 10.7.5.
                    I copied the contents of your first string to the "Save As" editing field of an unsaved InDesign document and saved the file with this name.
                    Then I ran the following code on the open document:
                    var string1 = "Chépitre.indd";
                    var string2 = app.documents[0].name;
                    $.writeln(string1.length); // 13
                    $.writeln(string2.length); // 14
                    I think, that's the proof that é in string2 is composed of two components: e + ´
                    So let's check this a bit in more depth:
                    $.writeln("string1.length" +"\t"+ string1.length);
                    // string1.length    13
                    $.writeln("string2.length" +"\t"+ string2.length); //EDITED
                    // string2.length    14 //EDITED
                    $.writeln("string1:");
                    for(var n=2;n<4;n++){
                        $.writeln(string1.slice(n,n+1) +"\t"+ string1.charCodeAt(n));
                        string1:
                        é    233
                        p    112
                    $.writeln("string2:");
                        $.writeln(string2.slice(n,n+1) +"\t"+string2.charCodeAt(n));
                        string2:
                        e    101
                        ́    769
                    That's it…
                    Uwe
                    • 7. Re: [JS] Variable text constructor
                      Btw. I'm on a German OSX with a German version of InDesign CS6.
                      Uwe
                      • 8. Re: [JS] Variable text constructor
                        Tested a bit more. On my German Mac OSX 10.7.5.
                        var string = "Chépitre.indd";
                        1. If I copy/paste the string over to the ESTK and then on to the Save As dialog to save an InDesign document, I get this: e + ´
                        2. If I rename an InDesign document in the Finder to the contents of the string using the keyboard any typing an ´ followed by an e, I also get this as app.documents[0].name : e + ´
                        3. If I copy/paste the string from the ESTK directly to the file name in the Finder to rename the InDesign document, I get: é with app.documents[0].name
                        4. If I copy/paste the string to an TextEdit file set to "Pure Text" with Encoding UTF8 and then copy/paste to the InDesign file in the Finder, I will get : é with app.documents[0].name
                        Uwe
                        • 9. Re: [JS] Variable text constructor
                          Liphou Level 2
                          Laubender thank you for your answer,
                          I used your code and I had no difference
                          so I copied the contents of my first string and "save as" the documents, I crashed the other file, I raise the code and I have the problem again.
                          Ok, two things but why ???
                          The file is located on a "Google Drive" ... the problem may be due to the transfer.
                          I had a problem at work but at home ... to meditate
                          Thank you.
                          Merci Laubender pour ta réponse,
                          j'ai utilisé ton code et je n'avais plus de différence,
                          j'ai donc copié le contenu de ma première chaîne et « enregistrer sous » le documents, j'ai ecrasé l'autre fichier, je relance le code et j'ai de nouveau le problème.
                          Ok, deux éléments mais pourquoi ???
                          Le fichier se trouve sur un "google Drive" ... le problème est peut être du au transfert.
                          J'avais le problème au travail mais plus chez moi ... à méditer
                          merci
                          • 10. Re: [JS] Variable text constructor
                            Hi Liphou,
                            in this regard see the following post by Martin Fischer at www.hilfdirselbst.ch in German.
                            He is using a table of replacements for Umlauts, because he had the same problems.
                            See his String.prototype.cleanUmlaut function.
                            Textdatei Importoption Zeichensatz Unicode - Adobe InDesign -  HilfDirSelbst.ch - Forum
                            In this post (back in 2008) he stated that he had no problems with combinations of áàéèóòúù, but years later he or someone else (including me) stumbled upon these and expanded his function. I recall a function that is placing images according to a list of file names that had the problems you encounter now.
                            See also from the same website from 2012:
                            Encodingdifferenzen zwischen Filesystem und javascript prompt
                            (differences of encoding between fle system and the javascript prompt)
                            Johannes Puff
                            http://www.hilfdirselbst.ch/foren/Encodingdifferenzen_zwischen_Filesystem_und_javascript_p rompt_P494483.html#494483
                            And also this one on hilfdirselbst from 2006:
                            http://www.hilfdirselbst.ch/foren/_P267653.html?search_string=Diaresis#267653
                            Uwe
                            • 11. Re: [JS] Variable text constructor
                              Liphou Level 2
                              Good evening and thank you Laubender for all these documentations.
                              To summarize,
                              I close the document, I open it again and resumes code ... no problem ...
                              Bonsoir et merci Laubender, pour toutes ces documentations.
                              Pour résumer,
                              je ferme ce document, je l'ouvre à nouveau et relance le code ... plus de problème ...
                              Merci à vous tous
