4 Replies Latest reply on Dec 16, 2015 2:13 AM by Loic.Aigon
    How to do a indeterminate checkbox with script UI
    creativejoan0425 Level 1
      there are actually three states a checkbox can be in: checked, unchecked, or indeterminate. but the value only show true or false
      w = new Window ("dialog");
      e = w.add ("checkbox", undefined, "test");
      e.indeterminate = true;
      w.show();
        • 1. Re: How to do a indeterminate checkbox with script UI
          Loic.Aigon Adobe Community Professional
          Don't think you can achieve this through the native Checkbox. Only workaround I can't think of is using a pseudo checkbox of your own like an 3 state image. Youc could get inspired by Marc Autret's work on using sprites in ScriptUI :
          http://www.indiscripts.com/post/2011/04/sprite-buttons-in-scriptui
          You can cook something based on events to deal with sprite states
          http://www.ozalto.com/en/event-driven-programming-with-extendscript/
          HTH
          Loic
          www.ozalto.com
          • 2. Re: How to do a indeterminate checkbox with script UI
            thanks I want to ask how to change the png graphic to code?
            • 3. Re: How to do a indeterminate checkbox with script UI
              Below is my Script, when run and click 3 times, there will not show the image, can u fix it?
              // Number of vertical sprites
              var V_SPRITES = 3;
              // InDesign CC Flag
              const CC_FLAG = +(9 <= parseFloat(app.version));
              // ScriptUI Image Offset Fixer in InDesign CS6 and earlier
              // (This bug has been solved in CC i.e. ScriptUI 6.2.x)
              const FIX_OFFSET = CC_FLAG ? 0 : 1;
              // Force an Image widget to repaint (= onDraw trigger)
              // CS4-CS6  ->  just reassigning this.size
              // CC       ->  we need to temporarily *change* the size
              // Note: using layout.layout(1) would not work anymore in CC
              Image.prototype.refresh = CC_FLAG ?
                function()
                var wh = this.size;
                this.size = [1+wh[0],1+wh[1]];
                this.size = [wh[0],wh[1]];
                wh = null;
                function()
                this.size = [this.size[0],this.size[1]];
              var myCheckboxValue = File("C:/Users/dtp/Desktop/UI_Checkbox_Graphic/checkbox_value.png");
                      var w = new Window("dialog","ScriptUI Sprites (CS4/CS5/CS6/CC)");
                              w.alignChildren = "left";
                      var myTopGroup = w.add ("group");
                             myTopGroup.alignChildren = ["fill","fill"];
                             myTopGroup.orientation = "row";
                          iButton = myTopGroup.add("image", undefined, myCheckboxValue, {state:0}),
                          iSize = iButton.image.size,
                          spriteHeight = iSize[1] / V_SPRITES;
                          iButton.size = [iSize[0], spriteHeight];
                         myTextIndentText = myTopGroup.add("statictext", undefined, "Text Indent")
              iButton.onDraw = function()
                var dy = this.properties.state*spriteHeight + FIX_OFFSET;
                this.graphics.drawImage(this.image,0,-dy);
              var mouseEventHandler = function(ev)
              //~ this.properties.state = ('mousedown'==ev.type)+2*('mousedown'==ev.type);
                this.properties.state = ('mousedown'==ev.type)+this.properties.state*('mousedown'==ev.type);
                this.refresh();
              //~     if(this.properties.state ==2){
              //~         this.properties.state =0;
              //~         this.refresh();
              //~ iButton.addEventListener('mouseover', mouseEventHandler);
              iButton.addEventListener('mousedown', mouseEventHandler);
              //~ iButton.addEventListener('mouseup', mouseEventHandler);
              //~ iButton.addEventListener('mouseout', mouseEventHandler);
              w.show();
              • 4. Re: How to do a indeterminate checkbox with script UI
                if you comment out the useful parts, you can't expect it to work
                if(this.properties.state ==3){
                this.refresh();
                Also you need to change 2 to 3
                HTH
                Loic
