3 Replies Latest reply on Dec 16, 2015 7:40 AM by Rick Gerard
    Make arrow appear as shooting through globe?
    Nomanativ
      Hey all,
      I amd a digial media student and I am currently learning the adobe suite. My cousin has a tv show on the outdoor channel and he wants a newer intro. What im trying to do is have an arrow shoot through a wooden globe (used CC Sphere) but i simply can not figure it out. please help! He is likely paying for this and i want it to be top quality.
      This is what i have so far:
      The globe rotates as i want it to but i do not know how to get the arrow "Inside" the globe to have it rotate WITH the globe.
      Message was edited by: Jayson Anderson
        • 1. Re: Make arrow appear as shooting through globe?
          Turn it into a 3D layer.
          Mylenium
          • 2. Re: Make arrow appear as shooting through globe?
            Flomotion70
            cc sphere is not a real 3D layer. So turning it into a 3D layer will give you a flat 3D layer of an image of a sphere.
            You could try to set your arrow to a 3D layer and animate it's rotation together with the cc sphere rotation. (or llink it to the rotation of the cc spehere).
            But.. you'll have to mask out the center of the arrow
            • 3. Re: Make arrow appear as shooting through globe?
              Unless your arrow is a 3D object in C4D or created with a 3D plug-in like Element or Zaxwerks it will turn into a thin line you can't see as it rotates. My suggestion would be to create both the sphere and the arrow in C4D lite (or a 3D plug-in). That's the only way the arrow is going to stay looking like an arrow as the globe rotates.
              If you just need to stick a 2D arrow through a CC Sphere globe then all you have to do is use a copy of your sphere layer rendered as inside or outside as a track matte for the arrow. The trick is that you need to put your sphere texture layer in it's own comp, duplicate that comp, then set up a track matte or a mask on the first copy that cuts a hole precisely in the middle of the texture dividing it into 3 pieces. The project would look like this:
              I've added expressions to tie the sphere radius to the top copy and to tie the rotations together. Once you get to 90º of rotation you will need to switch things around to make the matte work by adding another copy of the bg comp with the matte reversed.
