14 Replies Latest reply on Dec 19, 2015 8:47 AM by c0pajafe
    upgrades to 14.1 now wont unlock needed fies...
    c0pajafe
      upgraded to 14.1...
      now won't let me unlock components with  serial number
        • 1. Re: upgrades to 14.1 now wont unlock needed fies...
          A.T. Romano Level 7
          cupajafe
          What computer operating system?
          Did Premiere Elements 14 work before you updated it to the 14.1 Update?
          Please explain what you mean by "won't let me unlock components with serial number". Did you get beyond the Sign In page during the program install? Did you install from installation files purchased from Adobe or from installation disc purchased elsewhere?
          Please give more information.
          Thank you.
          ATR
          • 2. Re: upgrades to 14.1 now wont unlock needed fies...
            c0pajafe Level 1
            have registered copy on win10
            worked fine before it upgraded to 14.1
            initially installed before win 10 migration
            on first start up it needed me to do the encoder activation,
            so got activation code
            enter code
            windows asks ok to allow , i say yes
            and the cycle repeates
            tried rebooting
            uninstall and reinstall from disk
            get new code
            same doesn't take code problem...
            conrad
            Go on the 90 day challenge,
            www.conrad.bodybyvi.com
            On Wed, Dec 16, 2015 at 9:01 AM, A.T. Romano <forums_noreply@adobe.com>
            • 3. Re: upgrades to 14.1 now wont unlock needed fies...
              A.T. Romano Level 7
              copajafe
              Premiere Elements 14 on Windows 10 (assumed 64 bit).
              Are you doing an offline install?
              Do you have a purchased serial number?
              ATR
              • 4. Re: upgrades to 14.1 now wont unlock needed fies...
                c0pajafe Level 1
                FINAL RESULT IS IT WON'T LET ME BURN DVD...
                IT IS GRAYED OUT ON 14.0 REINSTALL, AFTER ENTERING CODE 5 TIMES
                conrad
                • 5. Re: upgrades to 14.1 now wont unlock needed fies...
                  c0pajafe Level 1
                  64
                  INSTALL FROM DISK
                  ONLINE INSTALL
                  GIFT DISK (BETA TESTER) WITH SERIAL NUMBER
                  conrad
                  On Wed, Dec 16, 2015 at 9:57 AM, A.T. Romano <forums_noreply@adobe.com>
                  • 6. Re: upgrades to 14.1 now wont unlock needed fies...
                    A.T. Romano Level 7
                    c0pajafe
                    Please download and install Premiere Elements 14 from the following link and insert your purchased serial number into it during installation when asked for.
                    Other downloads
                    Before you do that, please make sure of the integrity of the QuickTime install.
                    Do not update to 14.1 until you are sure 14 is working completely.
                    Check list...
                    1. Important: Have QuickTIme 7.7.6 installed on your Windows 10 64 bit. Apple - Support - Downloads
                    2. Are you running the programs as administrator (from user account with administrative privileges). And, in addition, have you right clicked 14's desktop icon and selected and applied Run As Administrator.
                    3. If your computer does not use an Intel HD Graphics 2000 or newer video card/graphics card, then disable the preference for this. See Edit Menu/Preferences/General.
                    At this time, I am understanding your issue as Export & Share/Disc/ issue....is this DVD?
                    What do you have set for
                    Type
                    Name
                    Destination
                    Please consider.
                    Thank you.
                    ATR
                    • 7. Re: upgrades to 14.1 now wont unlock needed fies...
                      c0pajafe Level 1
                      HELP!
                      PRE 14 has similar problems windows  or my security programs prevent
                      activation.
                      Dead in the water, and I have a few projects on the go
                      HELP!!!!
                      conrad
                      • 8. Re: upgrades to 14.1 now wont unlock needed fies...
                        c0pajafe Level 1
                        Thanks!
                        disregard latest text reply some how did not get your message above...
                        downloding 14 64
                        on the brighter side...
                        14 reinstall
                        run as admin seems to have solved the DVD burning greyed out problem...dvd iso image old style SD 480 destination image on disk
                        when i select burn it starts indexing... which I have never seen before... and seems to be getting nowhere fast...
                        stopped indexing
                        trying burn to DVD
                        indexing resumes...
                        so not yet solved...
                        checking quicktime...
                        and will look into 3
                        • 9. Re: upgrades to 14.1 now wont unlock needed fies...
                          A.T. Romano Level 7
                          Conrad
                          Thanks for the replies.
                          1. Let us determine if the following is involved
                          2. What is the duration of the Timeline content?
                          3. What is the formats of the Timeline content? Where are the originals stored? What is the computer processor and clock speed and other resources?
                          4. Did reverting back to 14 from 14.1 make a difference in the burn to indexing?
                          We will be watching for your progress as your time permits.
                          Thank you.
                          ATR
                          • 10. Re: upgrades to 14.1 now wont unlock needed fies...
                            c0pajafe Level 1
                            checked card is NVIDA GeForce GT 440
                            was checked I have unchecked this
                            Video and PSE worked before and after WIN 10 but not since 14.1 installed
                            2. What is the duration of the Timeline content? 1 hour 5 minutes
                            .MTS
                            stored on c drive
                            processor
                            indexing?
                            no still indexing with display unchecked
                            conrad
                            On Thu, Dec 17, 2015 at 10:24 AM, A.T. Romano <forums_noreply@adobe.com>
                            • 11. Re: upgrades to 14.1 now wont unlock needed fies...
                              A.T. Romano Level 7
                              Conrad
                              Let us see if the following will help with the prolonged indexing
                              Premiere Elements 14 on Windows 10 64 bit
                              Go to
                              File Explorer
                              This PC
                              Right Click Windows __OS (C:) and select Properties/General from the menu that appears.
                              At the bottom of General, remove the check mark next to "Allow files on this drive to have contents indexed in addition to file properties".
                              Restart the computer.
                              Please confirm where, at this time, you have the following stored on the hard drive
                              a. Timeline files
                              b. Preview files
                              If you look at Edit Menu/Preferences/Scratch Disks, where are each of the Scratch Disks categories saved to?
                              What is the longest time that you have waited for the indexing to stop? Is it always indexing messages? Do you ever see instead conforming messages?
                              ATR
                              • 12. Re: upgrades to 14.1 now wont unlock needed fies...
                                c0pajafe Level 1
                                Indexing turned off
                                hard drive
                                a. Timeline files
                                on c drive
                                b. Preview files
                                on c drive recreated before trying to burn
                                Scratch Disks categories saved to?  c:drive
                                hours, always just indexing
                                with no progress showing...
                                I have to go out today and will leave it run.....
                                thanks for the help
                                conrad
                                ATR
                                If the reply above answers your question, please take a moment to mark this
                                answer as correct by visiting:
                                https://forums.adobe.com/message/8313424#8313424 and clicking ‘Correct’
                                below the answer
                                Replies to this message go to everyone subscribed to this thread, not
                                directly to the person who posted the message. To post a reply, either
                                reply to this email or visit the message page: [
                                https://forums.adobe.com/message/8313424#8313424]
                                Please note that the Adobe Forums do not accept email attachments. If you
                                want to embed an image in your message please visit the thread in the forum
                                and click the camera icon:https://forums.adobe.com/message/8313424#8313424
                                To unsubscribe from this thread, please visit the message page at [
                                https://forums.adobe.com/message/8313424#8313424], click "Following" at the
                                top right, & "Stop Following"
                                Start a new discussion in Premiere Elements by email
                                <discussions-community-premiere_elements@adobe-v7.hosted.jivesoftware.com> or
                                at Adobe Community
                                <https://forums.adobe.com/choose-container.jspa?contentType=1&containerType=14&container=32 71>
                                For more information about maintaining your forum email notifications
                                please go tohttps://forums.adobe.com/thread/1516624.
                                conrad
                                On Fri, Dec 18, 2015 at 11:15 PM, A.T. Romano <forums_noreply@adobe.com>
                                • 13. Re: upgrades to 14.1 now wont unlock needed fies...
                                  A.T. Romano Level 7
                                  Conrad
                                  Thank for the replies.
                                  If the indexing during the burn to continues indefinitely (even if you start a new project with a different Timeline content), then consider getting Adobe involved while you still have the opportunity to do that for your recent purchase and current version. The suggested link for the Adobe contact is for online Adobe Chat/Downloading, Installing, and Setting Up....
                                  https://helpx.adobe.com/contact.html?step=PRE_downloading-installing-setting-up_downloadin g-installing_stillNeedHelp
                                  Your contact with Adobe does not prohibit us from troubleshooting here in the Premiere Elements Forum, but Adobe Chat might be able to offer you remote control of computer troubleshooting which we cannot here.
                                  We will be watching for your progress.
                                  Thank you again for the follow ups. Appreciated.
                                  ATR
