3 Replies Latest reply on Dec 17, 2015 10:34 AM by rosebudd
    Google display ads
    Derek Cross Adobe Community Professional
      Can you use Edge Animate to produce animated Google Display Ads?
        • 1. Re: Google display ads
          rosebudd Level 3
          If you uncheck use Hosted Adobe js file. And use this for your button action
          window.open(clickTag, "_blank");
          and put this in the published HTML file outside of the Edge runtime code but inside head
          var clickTag = "https://www.google.com";
          </script>
          • 2. Re: Google display ads
            Hi Rosebudd
            Thanks for that, though I'll have to unpick your answer!
            On another matter, I've mocked up an ad in Photoshop – each element is on a different layer. Is there a way of bringing these object into Edge Animate?
            Derek
            • 3. Re: Google display ads
              rosebudd Level 3
              PhotoShop CC has a generate function, where you name your layers with an extension to save as different file types.
              You can also copy and paste images from Illustrator directly into Edge
              AdWords has been really strict, no external files, that is why it is best to not use the Adobe CDN linked edge.js file.
