10 Replies Latest reply on Dec 17, 2015 11:24 AM by runew73276507
    Help with a javascript - need the document name in filename when exporting
    runew73276507 Level 1
      When I run this script:
      var myPresets = app.pdfExportPresets.everyItem().name;
      myPresets.unshift("- Select Preset -");
      var myWin = new Window('dialog', 'PDF Export Presets');
      myWin.orientation = 'row';
      with(myWin){
          myWin.sText = add('statictext', undefined, 'Select PDF Export preset:');
          myWin.myPDFExport = add('dropdownlist',undefined,undefined,{items:myPresets});
          myWin.myPDFExport.selection = 10;
          myWin.btnOK = add('button', undefined, 'OK');
      myWin.center();
      var myWindow = myWin.show();
      if(myWindow == true && myWin.myPDFExport.selection.index != 0){
          var myPreset = app.pdfExportPresets.item(String(myWin.myPDFExport.selection));
          myFile = File(File.saveDialog("Save file with preset: " + myPreset.name,"PDF files: *.pdf"));
          if(myFile != null){
              app.activeDocument.exportFile(ExportFormat.PDF_TYPE, myFile, false, myPreset);
          }else{
              alert("No File selected");
      }else{
          alert("No PDF Preset selected");
      I need it to place the document filname automatically when the "Save as" dialog pops up:
      Can anyone help me?
        • 1. Re: Help with a javascript - need the document name in filename when exporting
          Peter Kahrel Adobe Community Professional & MVP
          Use this:
          myPath = app.activeDocument.filePath + '/' + app.activeDocument.name.replace (/\.indd$/, '.pdf');
          myFile = File(myPath).saveDlg("Save file with preset: " + myPreset.name,"PDF files: *.pdf");
          Peter
          • 2. Re: Help with a javascript - need the document name in filename when exporting
            Dear Peter,
            Thank you very much - it works perfectly!
            Can you maybe help me with two other things in the same javascript?
            1. If I want it to remember last chosen folder to export to - where and what to write for that?
            2. If I before the export a PDF javascript code inside the InDesign document want to A: Resize a frame to a specific size - for instance 240x340mm - and B: Fit the placed file inside the frame with the function: Fit content to frame - can you do a javascript code for that?
            • 3. Re: Help with a javascript - need the document name in filename when exporting
              Write the folder that's used for the export to a disk file. When you run the script, check if the file is present. If it is, read it and use the folder name stored on the file; if it isn't use either a default value (such as the InDesign document's folder) or nothing at all, which shows the disk's root (probably).
              I don't really understand what you want here. Do you mean that you want to run a script before the export? Or do you want to store a script in the document?
              What is 'the placed file'?
              P.
              • 4. Re: Help with a javascript - need the document name in filename when exporting
                1. What I would like in the script is that a specific path on a server is chosen everytime i run the script - for instance \\filserver\data\output\
                Is it possible?
                2. I use this code in the same script today:
                if (app.selection.length != 0) {
                  for (n=0; n<app.selection.length; n++) {
                    app.selection[n].horizontalScale = app.selection[n].horizontalScale - 9.78;
                    app.selection[n].verticalScale = app.selection[n].verticalScale - 6.85;
                Instead I would like a specific size is made by the script - for instance 240x340 mm - and then fit the placed file - in this case a PDF file - to the framesize.
                Is it possible?
                • 5. Re: Help with a javascript - need the document name in filename when exporting
                  1: You could use something like this (I suppose):
                  myPath =  '//filserver/data/output/' + app.activeDocument.name.replace (/\.indd$/, '.pdf');
                  2: You could use geometricBounds, which is a 4-element array specifying top, left, bottom, right of a frame. (It's probably neater to use a transformation matrix but I can never remember the details.):
                  gb = app.selection[n].geometricBounds;
                  app.selection[n].geometricBounds = [gb[0], gb[1], gb[0]+340, [gb[1]+240];   // 340 tall, 240 wide
                  app.selection[n].fit (FitOptions.CONTENT_TO_FRAME);
                  P.
                  • 6. Re: Help with a javascript - need the document name in filename when exporting
                    1. When paste that code into here:
                      myPath =  '\\Polasaxoclustfs\SaxoGrafik\Side_Afsendelse_PDF' + app.activeDocument.name.replace (/\.indd$/, '.pdf');
                        if(myFile != null){
                    I get this result, when I run the script:
                    2. how to put in the gb code in this code:
                    with(myWin){
                        myWin.myPDFExport.selection = 0;
                    myWin.center();
                        if(myFile != null){
                        }else{
                    }else{
                    • 7. Re: Help with a javascript - need the document name in filename when exporting
                      Escape your backslashes: '\\\\Polasaxoclustfs\\SaxoGrafik\\Side. . .'
                      • 8. Re: Help with a javascript - need the document name in filename when exporting
                        1. then it just choose the same folder where the InDeisgn document is stored
                          myPath =  '\\\\Polasaxoclustfs\\SaxoGrafik\\Side_Afsendelse_PDF' + app.activeDocument.name.replace (/\.indd$/, '.pdf');
                        with(myWin){
                        myWin.center();
                            if(myFile != null){
                            }else{
                        }else{
                        • 9. Re: Help with a javascript - need the document name in filename when exporting
                          1. You forgot the slashes between the path and the document name:
                          myPath =  '\\\\Polasaxoclustfs\\SaxoGrafik\\Side_Afsendelse_PDF\\' + app.activeDocument.name.replace (/\.indd$/, '.pdf');
                          2. I don't know. Lots of questions. Looks like a drastic addition, time to hire someone.
                          P.
                          • 10. Re: Help with a javascript - need the document name in filename when exporting
                            1. Yes of course - it works perfectly now!
                            2. Fair enough - I am rookie but just very interested in Javascript to InDesign - thank you very much for your time Peter - I am really gratefull.
                            Have a nice christmas!
