23 Replies Latest reply on Oct 31, 2012 1:27 AM by EileenPalsson
    Snippets in drop-down text?
    EileenPalsson Level 1
      A user recently asked about using drop-downs in snippets. I need to do the opposite -- use snippets in the drop-down text in a help topic. Seems like it ought to be possible. But I haven't figured out how. Anyone?
      Thanks.
        • 1. Re: Snippets in drop-down text?
          vivek_k-GfmzA1 Level 1
          Hi Eileen,
          You can do this in RH8.
          Vivek.
          • 2. Re: Snippets in drop-down text?
            Thanks. Do you know for sure that it CAN'T be done in RH7? Or is there just some strange workaround?
            /Eileen
            • 3. Re: Snippets in drop-down text?
              RoboWizard Level 4
              Hi Eileen
              Some will tell you it cannot be done in 7. But I've done it as follows:
              Insert the snippet in the main part of the topic.
              Select the snippet in the topic and cut it to the Windows Clipboard.
              Open the DHTML drop-down window and paste it into the window.
              It may appear that if you update the snippet later it doesn't really update in the topic. But my testing seems to indicate that even though it seems this happens, the snippet is fine and updated in the compiled or generated version.
              As a side note, that's how I deal with ANY DHTML drop-down. I never ever just edit inside that little DHTML window. It drives me crazy to use it other than just to paste information into it. Even if I have an existing one where I need to modify a word slightly I will usually select all text, copy to the clipboard, paste into the topic and edit, select again and cut, then paste back into the window.
              Hope this helps you out... Rick
              • 4. Re: Snippets in drop-down text?
                Hi Rick,
                I really appreciate your input on this, because it would be VERY useful if I could get this working.
                I use DHTML drop-downs almost like you do, namely pasting text into them rather than editing text in them.
                But I can't get it to work with a snippet. I can copy in the snippet ok, and it looks fine in the preview. But if I switch to the HTML tab and back, the snippet disappears. Could you please try that?
                We have to be able to switch to HTML view without the snippet slipping away unnoticed. Perhaps you don't use that view as much as we do.
                If that's not making your snippet disappear, then I guess I need to start exploring on my side why our installation is acting differently. (We are using version 7.02.001.)
                Thank you
                Eileen
                • 5. Re: Snippets in drop-down text?
                  Hi Eileen
                  I work in the HTML view quite often. I just tested to be certain. My snippet remains if I edit the HTML.
                  Not sure what the difference is.
                  I think I'll blame sunspots... Rick
                  • 6. Re: Snippets in drop-down text?
                    Thank you for checking. What RH version are you using?
                    I just did this:
                    Upgraded to RH 7.0.3.
                    Created a clean, new project with one topic and one snippet. Inserted the snippet in a drop-down.
                    Switched to HTML view and added a space.
                    Switched back... and the snippet had disappeared from the drop-down. What the - ?
                    I need to solve this problem. Any ideas where to start?
                    /Eileen
                    • 7. Re: Snippets in drop-down text?
                      Ok, it doesn't look like my previous reply is legible. Weird.
                      I just did this:
                      1. Upgraded to RH 7.0.3.
                      2. Created a clean, new project with one topic and one snippet.
                      3. Inserted the snippet in a drop-down.
                      4. Switched to HTML view and added a space.
                      5. Switched back... and the snippet had disappeared from the drop-down. What the - ?
                      /Eileen
                      • 8. Re: Snippets in drop-down text?
                        Hi Eileen
                        Hmmm, I'm wondering if this is something that was changed in the last patch. I tested again this morning and finally saw the snippet disappear. I was upgraded to 7.0.3 over the weekend.
                        Grrrrr.... Rick
                        • 9. Re: Snippets in drop-down text?
                          Noooooooo! Please tell me they removed functionality! (Of course, I didn't get it to work before the patch, either. As I said, I was using 7.02.001 and the snippet was disappearing.)
                          Man I really need this to work.
                          /Eileen
                          • 10. Re: Snippets in drop-down text?
                            This seems like using a grenade launcher to kill a fly...
                            Possibly use an iFrame? Pop the snippet on a topic and reference the topic in the iFrame. Pop the iFrame into the DHTML drop down.
                            • 11. Re: Snippets in drop-down text?
                              I don't know what an iFrame is, but it does sound like an awkward way to do something that should be simple.
                              Isn't there some kind of code or comment that tells RH, "Leave this alone. Don't mess with this code." If there isn't, there should be. :-/
                              • 12. Re: Snippets in drop-down text?
                                RoboWizard Level 4
                                Hi Eileen
                                Yeah, be nice if there were an option for that.
                                Click here to view the WishForm/Bug Reporting Form
                                An iFrame is something RoboHelp 8 offers directly. But I've used them for years with RoboHelp. Basically they are inline Frames (iFrames). You create an iFrame and point it to a topic. It's a way to present another whole topic inside a topic.
                                The only other option that comes to mind is to use JavaScript to perform a "write in" of the code that is being deleted. I'm not sure if that would work any better. I would think RoboHelp may also delete the script. But it may not.
                                Cheers... Rick
                                • 13. Re: Snippets in drop-down text?
                                  I just tested Rick's method on a 7.0.2 machine and found that creating the snippet in the body of the topic and then pasting it into a dropdown worked just as long as I didn't close the topic. Once I did that, it broke and it also did not work in the output.
                                  Could you use variables instead? They can be added to a dropdowns and work OK.
                                  • 14. Re: Snippets in drop-down text?
                                    Hi Eileen,
                                    RoboHelp 7 does not have the feature to support snippet in Drop-down text. In other words, inserting only snippet inside drop down text will not work. However, there is a work around that should solve the purpose. You need to put some extra text or blank spaces before the snippet in Drop-Down text and it shall work fine.
                                    In RoboHelp8, this feature is available in proper form. You can drag drop snippet in Drop-Down or you can insert snippet through insert menu.
                                    Gunjan.
                                    • 15. Re: Snippets in drop-down text?
                                      Rick, Peter, Gunjan -- I reallly appreciate your input & efforts.
                                      Rick, I will fiddle around with that. And I'll be visiting the wish form / bug report site.
                                      Peter, this project also includes variables, so I'm very familiar with them. In this case, though, the text includes formatting, so it has to be a snippet.
                                      Gunjan, I was thrilled to see your potential workaround. Unfortunately, when I tried it, it didn't work. When I switch to the HTML view and make a change, then switch back, the snippet disappears from the drop-down.
                                      My team just upgraded from X5 to RH7 recently. And money is tight, so I can't see management approving another upgrade (to RH8) at this time. I guess it doesn't hurt to ask, though....
                                      I will keep working on this and get back to you if I find a solution that works. (Gunjan, please get back to us here if there is some detail of your workaround that I might have missed. Thanks!)
                                      Regards,
                                      Eileen
                                      • 16. Re: Snippets in drop-down text?
                                        Sshh! Don't tell Eileen that RH8 also allows you to format variables.
                                        • 17. Re: Snippets in drop-down text?
                                          Hi Eileen,
                                          In RoboHelp 7, such changes are lost if you switch twice from the HTML view with some changes in Design/HTML view. This behaviour has been enhanced in RoboHelp 8 and works fine.
                                          I think RoboHelp 8 is the only solution at present, without any workarounds :-)
                                          Gunjan
                                          • 18. Re: Snippets in drop-down text?
                                            Ok, I give up for now. I'm just going to paste the text into the drop-down (not a snippet). If it has to be retranslated 10 times, so be it -- until the next upgrade....
                                            Thanks for the input, all.
                                            /Eileen
                                            • 19. Re: Snippets in drop-down text?
                                              I submitted this request to Adobe, and they want more info - examples of when RH is changing users' code.
                                              I have my own example (this snippet thing). Does anybody have other examples I can give them? Peter, Rick? Here's our chance...
                                              /Eileen
                                              /Eileen
                                              • 20. Re: Snippets in drop-down text?
                                                RoboHelp knows better than to mess with MY code! Seriously it is not a problem that I have simply because of the nature of my content. However, this is a great opportunity for people to post examples of this problem which I know does give people grief.
                                                • 21. Re: Snippets in drop-down text?
                                                  I'd like to reopen this topic. (Or should I have started a new thread?) I upgraded (long ago) to RoboHelp 8.0.2, and in one project I am having a "snippets in dropdown" problem: When  I insert multiple snippets in a row inside a dropdown, only the first snippet stays inside the dropdown. The other snippets (and text that comes after that first snippet) appear outside the dropdown, both in Preview and in compiled help.
                                                  I am having this problem in one project but not others. For the life of me I can't figure out why.
                                                  Any ideas what could be causing this -- and how to solve it?
                                                  One thing I tried: Since I am under the impression that the project's eHlpDhtm.js file controls the behavior of DHTML effects, I tried copying the eHlpDhtm.js file from another project into the project where this problem is occurring. It didn't make any difference.
                                                  (I've searched this site and Grainge.org for 15 minutes without finding any reference to this problem.)
                                                  Grateful for any suggestions! Thanks.
                                                  • 22. Re: Snippets in drop-down text?
                                                    Hi there
                                                    How exactly have you tried inserting the snippets into the Drop-down?
                                                    If you tried the "RoboHelp" way of just plopping things into that frustrating little popup window, you might try a different approach. Insert the snippets directly into the topic as you would want to see them when the drop-down has been clicked. Then select them and cut them to the Windows Clipboard. Then paste that into the frustrating little window. See if that holds.
                                                    Another possible thought is that maybe create a single cell table and insert them into that. Maybe the additional container code for the table will cause the RoboHelp editor to see things differently? But I'd try the former first.
                                                    Cheers... Rick
                                                    • 23. Re: Snippets in drop-down text?
                                                      Rick, I hadn't used the RH way but had done exactly as you described, pasting the text into the frustrating little window.
                                                      So I tried your suggestion of creating a single-cell table and pasting them into that. It worked! What a creative idea! I'm really happy now. A thousand thanks!
                                                      I had a lot of them to do, so I added the table code directly in the HTML code, after the <DIV> tag:
                                                           <table cellspacing="0"><col style="width: 100%;" /><tr><td>
                                                      Then I added this right before the </DIV> tag:
                                                           </td></tr></table>
                                                      Perfect! Thanks again!
