1 Reply Latest reply on Feb 16, 2009 8:05 PM by Peter deHaan
    low stage quality messes up linkbuttons appearance
      Setting the quality of the stage to low affects the linkbutton in the attached code (modified example from http://blog.flexexamples.com/2008/09/04/using-an-embedded-font-with-the-linkbutton-control -in-flex/). First application: If you move your mouse over and out of the linkbutton a couple of times the linkbutton suddenly looks less than perfect. The somewhat strange thing is that this behaviour has some randomness to it. Sometimes it happens the first time you move your mouse, sometimes it happens after a while, sometimes it doesn't seem to happen at all. The second application looks less than perfect every time. It only happens in both cases when using embedded fonts.
      Has anybody else experienced this behaviour? Am I setting the stage quality the right way? Is there a problem using linkbutton and low quality?
      Any help would be much appreciated. Many thanks in advance.
