4 Replies Latest reply on Feb 16, 2009 9:28 AM by foq
    Can a SWF read posts?
    foq Level 1
      Hello. I hope you can, once again, help me with this one:
      I want to make a swf that can read (and display) random posts from a website made with drupal, geeklog or joomla (I'll choose whatever content manager works better with flash). Is that possible? Can you give any pointers?
      Thanks a lot.
        • 1. Re: Can a SWF read posts?
          Level 7
          foq,
          Sure.
          Yes. Flash supports XML, so if this site uses RSS (for example) to make
          posts available, you could read in that RSS (which is XML) and display it
          however you like. Even if your CMS doesn't support RSS, it makes its data
          available in text format, and that's all you need.
          As for pointers ... well, this could potetentially require a significant
          volume of custom code. The approach you decide to take in Flash will depend
          on the version of ActionScript you're using. You've posted to the
          ActionScript 1.0/2.0 forum, so is that your range? (In other words, no
          ActionScript 3.0?)
          David Stiller
          Adobe Community Expert
          Dev blog, http://www.quip.net/blog/
          "Luck is the residue of good design."
          • 2. Re: Can a SWF read posts?
            foq Level 1
            Hello David, thanks a lot for your help.
            The RSS idea is a good one. It would probably prevent me from displaying older content, but I could give up on that, for ease's sake.
            About which ActsionScript version: whichever is easier. I have more familiarity with ActionScript 1.0 / 2.0, so that would be my first option. However, as I should upgrade my license soon, ActionScript 3.0 would be great. What would you recommend?
            Again, thanks a lot!
            • 3. Re: Can a SWF read posts?
              Level 7
              foq,
              AS1/2 could certainly do it, but XML is more frustrating to navigate
              prior to AS3. AS3 supports something called E4X (EcmaScript for XML), which
              makes the data in XML significantly easier to access and manipulate.
              Ultimately, it depends on what version of Flash Player you want to
              support. If you're comfortable requiring your users to have Flash Player 9
              or higher, then go for AS3, by all means. Doing so will truly make your job
              easier.
              David Stiller
              • 4. Re: Can a SWF read posts?
                foq Level 1
                Ok, I'll try ActionScript 3 then. Thanks a lot!
