8 Replies Latest reply on Feb 13, 2009 1:48 AM by
    Linking swf files in Robohelp
      I have a Captivate slide with buttons, each button needs to run a captivate project (swf) within Robohelp. I have tried the ' Run other project' in Captivate and added the swf in RH as baggage but everytime I click the button is says the location of the file is incorrect. I think I am missing a link somewhere? Anyone been through this headache?
      Captivate 4 and RH8 used
      Cheers
        • 1. Re: Linking swf files in Robohelp
          Hi there
          So many potential wrinkles here!
          Problem could be on the Captivate side or the RoboHelp side.
          I'd begin by ensuring that the links work with the simple Captivate output. Once you are certain that's the case, then deal with RoboHelp.
          So the question here is: If you test the Captivate output prior to importing into RoboHelp, does it work there? If not, you have a Captivate linking issue to resolve before you begin thinking you need to resolve something in RoboHelp.
          Cheers... Rick
          • 2. Re: Linking swf files in Robohelp
            Thanks for the reply.
            It doesnt work in Captivate no. I thought I would try it in Robohelp as I thought it might handle it differently as that is where it is ultimately ending up.
            I get the 'cannot find file.cp.htm and file.cp.swf', which is strange because I dont have a .cp.swf or .cp.htm file, only .swf and .htm and .cp
            Do I need to export the 'external' linked swf file in a certain way?
            • 3. Re: Linking swf files in Robohelp
              Hi again
              Okay, so you have a basic Captivate linking issue to resolve.
              How are you linking from the buttons in Captivate?
              * Open other project
              * Open URL or file
              Cheers... Rick
              • 4. Re: Linking swf files in Robohelp
                I've tried both but thought I would stick with Open Other Project then Choose the .cp file which is to be linked.
                I copied all the output files from linked swf and copied them into the output of the 'linker' folder. When I run it, it lets me know that it cant find the cp.htm file from the old location of the linked project. This leads me to believe I need to export it differently.
                • 5. Re: Linking swf files in Robohelp
                  Hi again
                  Hmmm, normally the process is quite simple
                  * Insert the Button or Click Box and configure it to Open other Project when clicked.
                  * Browse to and choose the project you wish to link to.
                  * Publish all projects involved
                  * Copy all of them to the same folder
                  * Test
                  When you say it can't find the "cp.htm" file, are you meaning quite literally that you are seeing "cp.htm"? Or are you simply saying that you have a project (perhaps named MyProject) and the message indicates it can't find the "MyProject.htm" file? So you were using cp as a generic placeholder.
                  Cheers... Rick
                  • 6. Re: Linking swf files in Robohelp
                    its literally .cp.htm
                    I will have another go tomorrow following your points
                    Thanks alot
                    • 7. Re: Linking swf files in Robohelp
                      Hi again
                      If you want, I'll be happy to work with you tomorrow morning. Just shoot me a private email to rstone75 (at) kc (dot) rr (dot) com and include your phone number. I'll send you back a message with a link to follow so we can connect and I can watch your screen.
                      I'd like to see this in actual operation.
                      Cheers... Rick
                      • 8. Re: Linking swf files in Robohelp
                        Got the answer, its a bit random and nothing to do with RH or Captivate.
                        My p.c. has a partitioned drive d: where all my work is held including the Captivate stuff. I have been having small problems with it so I thought I would copy all files into c: drive and re-publish everything and yes it works a treat now !! Works in RH having added the swf as Baggage. Go figure? Not sure how it was setup. I only work here!
                        Thanks for everything Rick!
