2 Replies Latest reply on Dec 17, 2015 10:06 AM by johnbruso23
    How to use CFPARAM with list of string values
    johnbruso23 Level 1
      Hi All,
      I have a field value that can be stored with many values for a single record: Work_Order = '555555,666666,111111' (note, these are actually stored as a single string value in the db with commas .)
      I need to parse this field and enter the string values into the where clause of a new query:
      <CFSET WOIDS = CapProjects.Work_Order>
      <cfloop condition="#find(',,',WOIDS)#">
      <cfset WOIDS = "#rereplace(WOIDS,',,',',null,','ALL')#"><br>
      </cfloop>
        <cfquery name="CapProjectsWOIDS" datasource="#URL.DB#">
        SELECT [ENGOPSMTRLSID]
            ,[Work_Order]
        FROM ENGOPSMTRLS
        WHERE
      <CFOUTPUT>
        ENGOPSMTRLSID = #URL.INDEX#
      </CFOUTPUT>
      AND
      <CFOUTPUT>
        Work_Order in  (<cfloop index="idx" list="#variables.WOIDS#">
              <cfqueryparam
                              value=#WOIDS#
                              cfsqltype="cf_sql_varchar"
                               list="true"
                               /></cfloop>)
      </CFOUTPUT>
      </cfquery>
      Am I doing this right? I'm getting the following error: Error Executing Database Query. [Macromedia][SQLServer JDBC Driver][SQLServer]Incorrect syntax near '@P4'. Is that the loop length? How do I pass that in?
      John
        • 1. Re: How to use CFPARAM with list of string values
          WolfShade Level 4
          First, you don't need to use CFOUTPUT within a CFQUERY (or most/all other CFtags) - CF knows.
          Second, you don't need to loop a list for an "IN".  Unless you're using some obscure database that isn't MS-SQL, MySQL, or Oracle.  And you already know that CFQUERYPARAM has a list attribute.
          NOTE:  This is assuming that the datatype of Work_Order is char or varchar, not integer.
                ,[Work_Order]
            FROM ENGOPSMTRLS
            WHERE  ENGOPSMTRLSID = #URL.INDEX# /* <--- I didn't see URL anything, before this.  And I REALLY cannot stress how bad of an idea it is to use a URL variable for your DSN.  Just sayin'.  */
          AND
            Work_Order in  (<cfqueryparam
                                  value="#WOIDS#"
                                   list="true"/>)
          </cfquery>
          Since you are using a varchar for the type, you should put double-quotes around the value (line 08), as I have demonstrated.
          HTH,
          ^_^
          • 2. Re: How to use CFPARAM with list of string values
            johnbruso23 Level 1
            ahhh! double quotes! Thanks
