2 Replies Latest reply on Dec 22, 2015 7:57 AM by AIR-Chayah
    How can I view content of HHC outside of RoboHelp 15?
    AIR-Chayah Level 1
      RoboHelp 2015
      Visual Studio Source Control 2010
      This question probably crosses this forum and the Source Control forum.
      The Visual Studio Source Control check-in date for the HHC is October 2015 even though we have edited the TOC (in RoboHelp) and checked it back in many times since then.
      When we compare the server and the local workspace TOCs, they are identical.
      I spoke with our Team Foundation Server / Source Control administrator. He asked me to look at the contents of the TOC (HHC).
      When I open the HHC file with Notepad, I only get the info shown in the following screen. There is nothing in the HHC about the books or the topics in the books. (I thought we used to be able to open the HHC in a text editor and verify the book/topic structure.)
      Should I be concerned that the check-in date does not reflect the most recent check-ins?
      Thanks.
      Carol
        • 1. Re: How can I view content of HHC outside of RoboHelp 15?
          Willam van Weelden Adobe Community Professional & MVP
          This TOC is obviously empty, as you noted yourself as well. Just a sanity check: RoboHelp allows multiple TOC's. Are you looking at the correct TOC?
          If RoboHelp is showing the TOC, try to check out all files, make a change to the TOC, check in all files. The TOC needs to be checked in separately and that only happens when you check in all. The check out is to make sure another colleague isn't in the way.
          • 2. Re: How can I view content of HHC outside of RoboHelp 15?
            AIR-Chayah Level 1
            Thanks so much, Willam. You nailed it!
            Our original TOC was NGP_Help.hhc because the original product was called "NGP". Later, when the product had a  real name, "Touchstone", we renamed it to "Touchstone_Help.hhc". When I looked in Source Control, where everything is sorted alphabetically, I blanked on the fact that I was looking at the NGP TOC, not the Touchstone TOC.
            Regards, and happy holidays.
            Carol
